No power!
Old Dec 3, 2014 | 08:03 PM
Barnhill3289's Avatar
Barnhill3289
No power!
Bought an 86 f250 6.9idi diesel, poured white smk on the way home and had hardly any power barley could clime a hill, put a new injection pump on it, now it still has no power and when I had to the floor to see what it would do it started popping 3 or 4 times I let off it and took it back home. Any ideas on what could be going on?
Old Dec 3, 2014 | 09:19 PM
Forddiesel17's Avatar
Forddiesel17
Did the white smoke smell like fuel or sweet like coolant? Check the radiator while running; if there are bubbles while running most likely it is a blown head gasket. Did the smoke stop with the new ip?
Old Dec 4, 2014 | 08:40 AM
Barnhill3289
no power
The smoke didn't stop but it got a little better, and pretty sure the exhaust smells more on the fuel side, didn't check for bubbles in the radiator I can do that now.
Old Dec 4, 2014 | 08:54 AM
Forddiesel17
If it smells like fuel I bet that it is a bad injector. I had the same problem a couple months ago.
Old Dec 4, 2014 | 07:19 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
this is a good read on finding a bad injector and much more;
https://www.ford-trucks.com/forums/5...he-engine.html
Old Dec 4, 2014 | 07:38 PM
Barnhill3289
Would that cause it to have no power I changed one when I did the Injection pump and it looked fine the seals were still in good shape, I Dnt wanna spend $350 on injectors if I can run sum other test and figure it out
Old Dec 4, 2014 | 07:47 PM
FORDF250HDXLT
a bad injector can totally kill performance.there are other ways to find one (or more) other than the method used there.one quick method to find a stuck injector can be simply feeling the hard lines.if you feel one noticeably hotter than the others,then you know you've found a real bad one.i haven't tried it with the diesel (cus it's a clattery/loud engine) but you can take a long handle/screwdriver and place it on the injector with the engine running,and place your ear up to the handle of the screw driver and you can hear a nice sharp "click" as it pops.if you hear a much more faint "clicking" on one then you found a weak/bad one.
here's a guy showing the screwdriver method;
94 7.3idi
62
Oct 6, 2022 02:38 PM
Chriskerr86
Mar 18, 2021 11:14 AM
polky
Nov 7, 2012 06:41 AM
sloppyjoe
Nov 21, 2007 05:36 PM
1978fordf250
Nov 1, 2007 01:05 AM
