I recently scored the holy grail! I found a 4 speed tilt column for my '78. It needs the upper bearing replaced and a new turn signal switch. I called LMC since I didn't see the parts I needed in their catalog. Anyone have any insight on this? TIA
I will try to do a detailed post on the rebuild. I'm going to have kind of a tight window to get this done when I go home for Christmas. Hopefully I can locate the parts I need before then. Any help will be appreciated!!
I am sooooo green with envy but am really happy for ya. Congrats.
Let's raise our grails and toast PEB on a job well done!!
I haven't had much luck finding out for sure which bearing it takes. Guess I will just have to wait till I get home, tear it apart and get some measurements. Unless someone comes up with some info before then. I'm stoked......had a usable sport wheel, the horn button even works! Also had the correct cover for where the column meets the dash!
i just rebuilt my steering column. 74 f350 2wd i got the parts from bronco graveyard. dont order online tho. call them and be on there site from your computer. tell him what you want and double check the numbers from the site. until you find what you need. i saved the baggy`s they were in , if you want the part numbers i used , let me know.
i just rebuilt my steering column. 74 f350 2wd. those are the same part numbers in that picture that my bearings used. i got the parts from bronco graveyard. dont order online tho. call them and be on there site from your computer. tell him what you want and double check the numbers from the site. until you find what you need. i saved the baggy`s they were in , if you want the part numbers i used , let me know.
just for giggles.. are these years trucks supposed to cancel the signal lights automatically when turning the wheel back? mine doesnt do that at all... thinking that diagram is going to come in handy...
My 76 doesn't cancel because 18 years ago when I was putting in an aftermarket steering wheel, I couldn't figure out how to get the cam that cancels the switch off without breaking it. I just replaced my column and turn signal switch last weekend and the new column didn't have a cancel cam with it. I did see that Dennis Carpenter has that part listed. I'm may order it and try to restore order. Those people that try to turn left in front of me when I've forgotten to cancel my signal will appreciate it.
Turn Signal Switch
Fits 78-79 E/F100-350 w/ tilt wheel
D8TA-13341-A
NOS Parts Source, Olathe, KS has 1 (913) 220-5746
There are two bearing possibilities:
Bearing Assy, upper, steering column, 78-79 w/ tilt
1 1/16" ID X 1 1/2" OD
C7SZ-3517-C
Dennis Carpenter, Concord, NC has 21 (704) 786-8139
Green Sales, Cincinnati, OH has 16, (800)543-4959
Parts International, Farmers Branch, TX has 17, (972) 241-8730
Bearing assy
3/4" ID X 1 3/16" OD
C7SZ-3517-D
The Lincoln/Mercury Old Parts Store, Clearwater, FL has 1 (727) 445-7551
Mustangs Etc, Van Nuys, CA has 1 (818) 787-7634
Turn Signal Switch
Fits 78-79 E/F100-350 & Bronco w/ tilt wheel
D8TZ-13341-A / Available from Ford / MSRP: $150.02
FTE sponsor silverstatefordparts.com online price: $99.01 / Gaudin Ford ~ Las Vegas NV
FTE sponsor horizonpartsguy.com price: $108.01 / Horizon Ford ~ Seattle (Tukwila) WA
C7SZ-3517-C
Dennis Carpenter, Concord, NC has 21 (704) 786-8139 / 800-476-9653.
Green Sales, Cincinnati, OH has 16, (800) 543-4959
Parts International, Farmers Branch, TX has 17, (972) 241-8730 / 888-727-0418.
Bearing assy
3/4" ID X 1 3/16" OD F23Z-3517-Breplaced C7SZ-3517-D / Available from Ford
I just rebuilt my steering column. 74 f350 2wd. those are the same part numbers in that picture my bearings used.
The basic part numbers are the same, but the tilt steering column bearings are not the same as your 1974 F350 (all F350's thru 1978 are 2WD).
Only basic part numbers are shown in parts catalog illustrations. The text section is required to get the complete part number by adding the apropos prefix and suffix.
