Sponsored by: Auxito
LEAKY WINDOW
Old Dec 3, 2014 | 06:20 AM
Se7vinDeadlySins's Avatar
Se7vinDeadlySins
LEAKY WINDOW
Hey all,
I have a 2001 f150 supercrew, and the rear window leaks like crazy when it rains. Has anyone else had or still have this problem? What did it take to fix it and approx. how much?
Old Dec 3, 2014 | 08:03 AM
blupupher's Avatar
blupupher
Common problem.
The seal around the back window has gone bad. You need to remeve the rear window (not too hard) and replace the window sealant.
Use some 3m Window Weld butyl tape (do not use the liquid stuff in a tube).
Old Dec 3, 2014 | 09:25 AM
highflyindude's Avatar
highflyindude
Or just pay someone 100-150$ and save your time
Old Dec 3, 2014 | 09:57 AM
Se7vinDeadlySins
Thanks guys. good info.
Old Dec 3, 2014 | 12:36 PM
blupupher's Avatar
blupupher
Why spend $100+ when you can spend $20 and a few hours doing it yourself.
Were not all made of money.
Old Dec 4, 2014 | 04:10 PM
Spotty's Avatar
Spotty
LOL...I ran a bead of 100% clear silicon across the top and down 5" on both sides on my old 98 just to get me by until spring. It kept the water out for 8 years and still didn't leak when I sold it. Not the correct fix, but it worked.
Old Dec 4, 2014 | 04:26 PM
blupupher's Avatar
blupupher
You got lucky, most that do that still have a leak plus have that mess to clean up along with it.
Old Dec 5, 2014 | 07:53 AM
crampus's Avatar
crampus
The tube urethane works fine, just get the 3M window weld. It works. Theres a tutorial on you tube of the removal of the rear window... it takes the user four hours, it only takes 15 mins. Cleaning off the old sealent is the longest step,, its a pia.
Prep sufaces with alcohol or similar, and get a monkey to help with install. Wear nitrile gloves, and dont get that urethane on your butt like I did, I now have a stain on my seat!!!!!
And be careful removing the rear plastc molding. . Its like $550 for a new one!!!!!
Old Dec 5, 2014 | 05:35 PM
steve(ill)'s Avatar
steve(ill)
window can be removed without removing the outside trim. You have to remove the trim around the head linger to get the window bolts out. I have used the butyl strip to do the job. There is a kit that you buy (auto zone) specifically for the job. Original is butyl from the factory, but was not installed correct.
Old Dec 6, 2014 | 06:57 AM
crampus's Avatar
crampus
I took my exterior trim off to check the seams all over, because my leak was so large.
Yes it was the window only, I could have done it wo removing the trim...
I just couldnt believe that big of a leak was just the window. But yeah, its just the dammned window seal, a 1 inch section was completely unattached from the body of the cab. It appeared to have been for quite awhile.
Old Dec 7, 2014 | 08:20 AM
blupupher's Avatar
blupupher
[QUOTE=crampus;14877462]The tube urethane works fine, just get the 3M window weld. It works. Theres a tutorial on you tube of the removal of the rear window... it takes the user four hours, it only takes 15 mins. Cleaning off the old sealent is the longest step,, its a pia. /QUOTE]
Yes the tube stuff works, but it is a huge mess and can get everywhere. the butyl tape is not messy and seals well.
Mine was about 1" also.
greggara
6.7L Power Stroke Diesel
Mar 22, 2011 06:48 PM
frdkid88
1997 - 2003 F150
Apr 11, 2008 03:06 PM
f-150 on 22's
2004 - 2008 F150
Sep 4, 2007 09:11 AM
Ultramagdan
1997 - 2003 F150
Aug 26, 2003 07:12 PM
Cameo
1978 - 1996 Big Bronco
May 27, 2003 11:42 PM
