wiring issue
Old Dec 2, 2014 | 07:13 PM
saauvenshine's Avatar
saauvenshine
Question wiring issue
I was putting a 12 to 6 volt reducer from napa to my gas and temp gauges on my 1954 ford truck. I was told to run a wire from ignition switch to the terminal on reducer that's marked batt and then run a wire from the other terminal of reducer to the gas gauge then loop a wire to the temp gauge. What terminal on the ignition switch do I run the wire off of they are marked ign,acc,batt,with a long post in the center. Also what terminal on ignition switch do I need to run my wipers and heater motor to wasn't sure if the long terminal in the middle was hot or not.Thanks guys.
Old Dec 3, 2014 | 04:50 PM
mustangmike6996's Avatar
mustangmike6996
https://www.ford-trucks.com/forums/8...o-12-volt.html
Gramps67highboy
Sep 1, 2015 12:48 AM
1loco
Jul 2, 2014 09:21 PM
low54
Aug 2, 2011 03:42 PM
F100dawg
Jan 20, 2010 07:42 PM
sl9mk
Electrical Systems/Wiring
Dec 29, 2003 02:56 PM
