Need wire help
Old Aug 2, 2011 | 01:30 PM
low54's Avatar
low54
Need wire help
I posted earlier about wiring the starter button,...Info first...I'm using rebel wiring, its like EZ...I also, have a ign switch that has only three posts...one says "coil, second says, bat, then AC...I however need more clarification...Do I run the ign wire from the 1-wire alternator to the button first then run a wire to the coil side of the ign switch?...I'm confused when to run the alternator wire too...thanks...
Old Aug 2, 2011 | 01:44 PM
mtflat's Avatar
mtflat
Ignition and charging systems are separate - generally.
Wire from ignition switch (coil) to the coil. May run thru a resistor if using points and coil without internal resistance.
Wire from ignition switch (AC) to the gauge panel
Wire from ignition switch (BAT) to power that usually comes from the fuse block.
One wire alt should only go to the battery side of the solenoid (relay) afaik
Old Aug 2, 2011 | 03:40 PM
53OlderThanMe's Avatar
53OlderThanMe
I would say follow the instructions from the Rebel Wiring kit which shows how to wire a GM 1 wire alternator. On the ignition switch I'm really not sure as you only have 3 of the 4 posts. I would call or email Rebel and ask them. I don't know if you don't have an IGN post because its an original switch and you have the starter button. I am using a newer after market switch which allows me to by pass the starter button if desired. Remember in the wiring kit there are groups of wire that go to the dash, front, back and engine of the vehicle. Some of these have the same name and color but are really 2 ends of the same wire running thru the fuse box. Make sure you separate these groups properly and tape or tie them off to keep them together.
This is what my switch looks like http://cgi.ebay.com/ebaymotors/NOS-1...item35b41be5dd
Old Aug 2, 2011 | 03:42 PM
53OlderThanMe
Bump to get off my EVIL 666 post count.
Gramps67highboy
Sep 1, 2015 12:48 AM
351Cleveland C4
16
Aug 26, 2014 10:01 AM
F100dawg
Jan 20, 2010 07:42 PM
Woodsman_30350
Electrical Systems/Wiring
Aug 26, 2008 08:53 PM
BigShelby
22
Jun 15, 2007 08:33 PM
