I replaced the gas tank sending unit in my 64 f100. The fuel gauge went up to 3/4 tank so I drove to the gas station and put in 7 gallons and the gauge didn't move. I grounded it but it's kinda makeshift and needs to be done better. Could this be the issue? Thanks
What happens when you ground out the wire going to the sending unit? This should make the fuel gauge rise to full. If it doesn't, then you have a wiring issue of some kind.
Also, if the new sending unit came without a new float, did you replace the float with a new one?
Or make sure the old one was not leaking, and was empty before installing it on the new float?
Assuming the gauge itself is OK, and it probably is, you have to calibrate the sender and gauge. I don't know if the original sending units have this adjustment but the repops do. Drove me nuts trying to figure this out and spent 25 bucks on a CVR and there wasn't anything wrong with the original sender, either? $75 down the drain. But you can learn from my mistake!
Loosen the set screw on the float arm at the sending unit and while holding the pivot pin stationary, rotate the arm up about an 1/8th in. on axis and tighten set screw.
Check that fuel gauge indicates full when arm is resting at the high stop. Adjust as required, if the gauge for example indicates 3/4 with an empty tank just move the business end down. Hope this helps.
My sending unit works weather the ground wire is connected or not. The sending unit is grounded to the tank by the screws that attach the sending unit and the tank in grounded to the body. I have the same results ground wire or not.
Go figure?
See the round part where the arm connects with the sender itself? Setscrew for adjustment should be right there. If not, make somethin' happen. Easy peasy. The instructions don't mention this iirc.
Go figure?
The ground wire on the top of the sending unit is a secondary ground, allegedly designed to reduce sparking between the sending unit and the tank if the sending unit is removed or loosened while energized.
Sparks at the gas tank opening would have unpleasant results, of course.
My request to the original poster was to ground out the wire from the gauge, to make sure the gauge and wiring were functioning correctly.
D7TZ-9275-G (replaced C1TZ-9275-K & D0TZ-9275-A) .. In-Cab Fuel Tank Sending Unit / Obsolete
1961/77 F100/750 - 1963/69 N/NT/T500/750 - 1967/69 F800/1000.
The fuel tank sending unit float is made from two pieces of copper soldered together.
Solder breaks down, gas seeps in, float settles to the bottom of the tank.
The float (C0AZ-9202-B) is the same: 1957/79 Passenger Cars/Trucks - 1961/79 Econoline - 1966/79 Bronco.
This float is available from Ford, but Carpenter sells a one piece brass float that'll never leak for about 5 bucks.
