Radiator Selection advice
Old Nov 30, 2014 | 03:10 PM
johnson.jeff.a's Avatar
johnson.jeff.a
back for more.....55 f100 originally straight 6. Now has a 292 from an early 60s f100.
Radiator has a small leak (bigger when warm). Looking at replacement options.
The current radiator is stock style with top hose center and bottom hose on driver side.
I may be replacing the 292 within a year or so, but not sure what with yet.....302, 351 most likely candidates. Will likely also add power steering and a/c eventualy.
From those with experience, what radiator configuration has the best hope of working (without too much hassle) in those situations? Am I crazy for trying to plan ahead?
Any thoughts on sources also appreciated.... Been looking at midfifty's options.
Old Nov 30, 2014 | 03:42 PM
Doc's Avatar
Doc
Find a radiator repair shop and see if they can repair it. You'd be amazed at what they can fix sometimes. You gotta remove it either way......give it a shot. Will save you $$$.
danlee
Jul 10, 2018 08:24 PM
Ki-Adi-Mundi
15
May 8, 2017 05:32 PM
Schuey
19
Nov 16, 2014 01:10 PM
Gatsby
Jan 21, 2005 02:37 PM
66sprintw53
May 3, 2004 10:13 PM
