Contemplating new exhaust
Old Nov 30, 2014 | 11:09 AM
BaronVonAutomatc's Avatar
BaronVonAutomatc
Been driving the heck out of the 96 F150 I picked up and it seems like the catalytic converter(s) are not so good. The exhaust stinks and it feels like the engine struggles to breathe a bit at highway speeds. Highway speed between here and the deer lease is ~80 mph. A better breathing exhaust has got to help.
I've got a 3" converter sitting around, so I'm thinking about a single 3" exhaust. I had a similar system on the 302 in my old F250 (sans converter) and it worked well. Anyone running a 3" single on their 300?
Old Nov 30, 2014 | 03:43 PM
Biblethumpncop's Avatar
Biblethumpncop
I have EFI exhaust manifolds, a custom Y-pipe and a single 3" stock muffler (no cat) on my son's 72 F-100 with a 300/6. The P/O put a cam, Offy C intake and Holley 390 on the truck.
Old Nov 30, 2014 | 06:19 PM
BaronVonAutomatc
Sweet, I ordered a giant 30" long Magnaflow straight-through muffler to go behind that 3" 3-way converter I had in the shed. Should free up the flow nicely and still be pleasant at highway speeds.
Old Dec 1, 2014 | 02:39 AM
trozei's Avatar
trozei
Why not delete the cat?
Old Dec 1, 2014 | 05:43 PM
BaronVonAutomatc
Why delete the cat?
Old Dec 1, 2014 | 08:26 PM
trozei's Avatar
trozei
The cat is a flow restriction.
Old Dec 1, 2014 | 08:51 PM
Harte3's Avatar
Harte3
Not enough flow restriction to make a difference especially using a contemporary high-flow Cat.
Old Dec 1, 2014 | 09:44 PM
trozei's Avatar
trozei
It makes enough of a difference to justify not bothering to replace it.
Old Dec 1, 2014 | 10:11 PM
AbandonedBronco's Avatar
AbandonedBronco
It's a social responsibility to replace it, not just a government enforced one. They're on there for a very good reason, and as being someone who's eyes burn from smog whenever there's a local inversion, I'll take every bit of clean air I can get.
A healthy cat has very little detrimental change on performance.
Old Dec 1, 2014 | 11:12 PM
Tedster9's Avatar
Tedster9
He's in Texas. You'll be fine.
Old Dec 2, 2014 | 08:41 AM
AbandonedBronco
Seriously, that kind of sarcasm isn't constructive or needed.
It's a mentality that affects everyone everywhere because people want a "little extra" at the expense of everyone else. It's not a mindset that should be propagated on the forums.
Old Dec 2, 2014 | 02:23 PM
ZarK-eh's Avatar
ZarK-eh
My truck never had one.
However, I installed an EFI on it, and plan to add the cat as well, and hook up the EGR as well. Just because it ain't there doesn't mean it shouldn't.
Yup, Imma greenie better to build an old truck than throw it away and buy new.
Old Dec 2, 2014 | 06:06 PM
BaronVonAutomatc
Well the truck still has to pass inspection, if it's throwing a code because the converter has been removed it won't pass.
Since I'm replacing the stock 2" headpipes and 2.5" exhaust with 2.25" and 3" pipes AND replacing the 20 year old 2 converter system with a single 3" the exhaust will flow significantly more than it does now. Why not use a part that's gathering dust in my garage to keep it legal?
Old Dec 3, 2014 | 12:50 AM
trozei's Avatar
trozei
Unless you have both an upstream and a downstream O2 sensor, a malfunctioning or nonexistent catalytic converter will not throw a code.
Old Dec 3, 2014 | 04:51 PM
BaronVonAutomatc
Yes, the truck has two O2 sensors upstream and one downstream from the converter. I'm pretty sure that's why there's no tailpipe test required for OBDII vehicles in Texas.
