It's always possible to get a bad part. Does your signal indicator on the dash still remain steady rather then blinking when you put on the brakes? If thats the case it almost sounds like you have a may have 2 wires switched were the column wires plug into the wiring harness.
could be a broken wire in one of the connectors or in that wire for that side ? starting at the rear with a test light go back and probe the wire every couple of feet until you get to the beginning
with problems like these a test light can be your best friend because its fast and absolute .
Indeed it does. Which two wires would I look for? Everything else seems to be working properly.
I actually used a multimeter to test the continuity to the back, and there's zero resistance. Plugging the right light into the left circuit works perfectly, so everything downstream of the plugs at the column appears good.
~Steve
At my age my crystal ball is getting a little foggy.. The wires are all color coded but sometimes the exposed ones fade or don't appear as they were when new. I would suggest peeling back some of the tape and see what the colors look like further back to start with. Some of them have two colors like a thin white/ black/ red line that I have a hard time seeing at times.
Try using your meter to check one wire at a time coming from the turn signal switch with the right turn signal turned on.
Sorry, your answer was so specific, I assumed you'd seen the problem before and might know which wires were crossed.
Took me a while to get to it, but went through the wires yesterday--found that the right rear turn and brake light switch wires were switched up. In my defense, the colors on the replacement turn signal switch did not match the factory codes. (Sheesh!)
