I have a 2005 F-150 and I was wondering if there are any drawbacks to installing a 10.5 full float rear axle. I saw on another forum that the truck would "take more to turn the bigger axle". How true is this? Other than the different wheels, are there any drawbacks to doing this? I would like to increase payload.
You can't increase payload because on the drivers door is a sticker that says the gvwr of the truck. There is no way to increase the gvrw of the truck other than jacking up the rad cap and putting a 3/4 or one ton underneath it.
"full float" refers to heavy 3/4 or 1 ton axles. You would have 8 bolt wheels with that setup...... The rest of the truck , as mentioned, would still be light duty... transmission / motor / springs / front axle / frame... etc ....... what are you trying to do ? If your putting more weight in the bed of the truck , you can add helper springs ... but don't go over the rating for the remainder of the truck......... If you want pulling power, change the rear axle gear ratio, not the axle type.
I understand the GVWR would not be changed. I may be pulling near 9000 pounds and was concerned about tongue weight on the axle shafts.
I know the 5.4 can do it since it was an available engine on 2005 F-250s, and the frame is 36 thousand p.s.i., same as the F-250 frame I believe. Springs would be upgraded, so transmission would be the light duty part along with the front suspension.
I want to know how much more torque is required to turn the wheels on a 10.5 vs. a 9.75 axle.
As far as turning a 10.5 vs a 9.75 i dont imagine its much. Dont forget most 150's with 5.4 motors will pull a 9k trailer and thats with a 9.75 axle. I Believe the rating on these are 3800 and 4050 lbs. Dont forget you shouldnt go over the gawr on the trucks and the fact if you had a larger axle you would go over gvw before you could gross out the heavier axle.
Thanks!
Are you pulling 9000 pounds or are you looking at 9000 pounds of tongue weight? A 8.8 will even pull that no problem, I've pulled 25,000 pounds of farm wagons with a my old 94 f150 with an 8.8 but the max bed/pin weight it would handle was around 4,000 lbs, with a leaf springs in back from a f250 otherwise bone stock. I buy no means recommend trying this as it maxed out absolutely everything on my 94 f150 with a 8.8 especially the breaks and tires!!! Your rear axel is buy far a weak point it will take anything the rest of the truck can throw at it and then some.
With a trailer, you still load it so it has a given tongue weight. Normally that is 500- 700 pounds. The other 8500 pounds is on the trailer tires..... Your main concern should be brakes and transmission.. Your rear axle gear ratio will determine how fast you can get up to speed ..Drive shaft U joints may be smaller version also.
Have there been any brake upgrades done on these F-150s?
You can put drilled/slotted rotors and aftermarket pads on for "increased brakeing performance" but my 05 expedition has more the adequate stoping power stock, pulled a 8000+# TT all over the Black Hills and unless going over 70 mph or pulling a very steep grade you could almost forget the trailer was back there. The two best things for towing I would recommend, A good weight distributing hitch with sway control and a good Electric brake controller as I've had some that were just plain annoying.
What engine and axel gearing do you have? That will be the biggist limiting factors for what your looking to tow. I probably wouldn't try it with the 4.6 and definitely not with the 4.2. The 5.4 will struggle if you have 3.55 gears, 3.73 or lower are much better for towing.
