400 thermastat correct setup?
Old Nov 29, 2014 | 12:49 AM
wyoming4x4's Avatar
wyoming4x4
Need proper thermostat for my 400. My problem is not making enough heat. Makes heat but once I get rolling things cool down pretty quick. Have a 180 degree in it now. Will be going to elec fans soon to help control temp. Usually these engines run hot but not this situation.
Old Nov 29, 2014 | 01:13 AM
mustang81's Avatar
mustang81
I had that problem and my small radiator inside was almost plug. Try to run a hose back and fort into the 2 pipes from the firerwall.
Old Nov 29, 2014 | 01:29 AM
351Cleveland C4's Avatar
351Cleveland C4
I'd suggest flushing the system and installing a 195 thermostat. If that doesn't do it, another trick is putting some cardboard in front of the radiator.
Old Nov 29, 2014 | 07:32 AM
Gary Lewis's Avatar
Gary Lewis
I agree - flush it. But, start by back flushing, meaning put the water in where it has been coming out. That way what is plugging the radiator should be blown off instead of more tightly plugged.
And, you are using the proper type thermostat? One made for the Cleveland?
Old Nov 29, 2014 | 09:00 PM
wyoming4x4's Avatar
wyoming4x4
Thermostat issue!
Apparently using wrong part. Have aluminum radiator and it's good to go! Believe my coolant system working too good. Or just wrong thermostat. What is the correct part#.
Old Nov 29, 2014 | 09:22 PM
Gary Lewis's Avatar
Gary Lewis
I ordered the Gates 192 degree, part #33129, from Amazon.
Old Nov 29, 2014 | 11:10 PM
wyoming4x4's Avatar
wyoming4x4
Thanks Gary!
Will get ordered! It's 0 degrees at the moment! Have a little cool weather blowing through for a day or two! Thanks!
beartracks
Oct 19, 2017 12:28 PM
jonlucille
Nov 12, 2010 09:49 PM
BlueOvalfan85
May 17, 2007 10:59 PM
dkchristensen
Aug 1, 2003 12:05 PM
mcguyver
May 31, 2003 12:00 PM
