Prestone OK?
Old Nov 28, 2014 | 06:26 PM
jack orchard's Avatar
jack orchard
Prestone OK?
I have 6 new gallons of Prestone anti-freeze which is about 5 years old. Will i be OK if i use some of this instead of the Ford stuff in my 2005 E150 w/4.6 engine?
Many thanks to all.,...jack
Old Nov 28, 2014 | 07:07 PM
guitarpicr's Avatar
guitarpicr
I use the prestone prediluted extended life 50/50 yellow - It says it will work/mix with any of the new anti freeze no matter the color. Not sure if that helps you or not. Is it the pre cut or full strength that you have? Dont think the age will matter as long as it was not open. If full strength make sure to cut 50/50 using distilled water only
Old Nov 28, 2014 | 07:31 PM
Wildman25's Avatar
Wildman25
I'll agree, new, in a plastic jug, should be no problem, I don't think there is a "shelf life" on anti-freeze.
Once in place in the engine/radiator, different story, exposed to the pressures, heat, killing the ph levels.
And, at today's prices for anti-freeze........Great Find
jack orchard
It is full strength. Unopened. I also plan to use the Ford VC1 flush. All old coolant will be removed. Thanks,...jack
Old Nov 28, 2014 | 08:01 PM
guitarpicr's Avatar
guitarpicr
Jack - I have done some reading on this since replying to your post,& it seems there is no real clear cut answer as the different motors have different amounts of aluminums & alloys & each one seems to use different coolants,per fomoco. That said - I dont want to mislead you as my van only has 60 k and I have only used this as a topping off coolant. My owners manual states the coolant (yellow or gold VC7-A) is good for 100 k. Might want to get some other more knowledgable opinions on this b4 using what you have, to be on the safe side.
Gage2502
Modular V10 (6.8l)
Jun 21, 2012 03:58 PM
Jolly Roger Joe
Nov 10, 2011 10:09 AM
jaxmark
Escape & Escape Hybrid
Feb 2, 2011 09:51 PM
oldfordf600
May 29, 2010 12:46 PM
Pony Power
Sep 3, 2006 07:38 AM
