65+ problems
Old Nov 28, 2014 | 03:11 PM
jmahle67's Avatar
jmahle67
65+ problems
hey guys new 6.0 owner with a problem. I just had to have ficm and 2 injectors changed due to having loss of power on the highway. I would lose power at 55+. i would just be cruising and suddenly lose power and then go to press the go pedal and nothing would be there. Well now after ficm and 2 injectors truck runs fine but still has loss of power problems very sporadically. it seems to mainly occur at 65+. any ideas?
Old Nov 28, 2014 | 05:24 PM
Yahiko's Avatar
Yahiko
Gauges? And I don't mean the factory ones.
You need to know what the PCM is seeing
to really help find the problem.
With some thing like the Scanguage II or one of the smartphone
tools and software you should be able to pinpoint this.
Look at Vref to see if for some reason it's dropping out.
Also a do you have the blue spring update regulator done?
I would verify the fuel pressure under load to see if it's
dropping below 45PSI. Low pressure is hard on injectors.
Sean
Old Nov 29, 2014 | 09:37 AM
cheezit's Avatar
cheezit
Stuck turbo?
Old Nov 29, 2014 | 09:49 AM
woodlander's Avatar
woodlander
Ya I had similar issue with vanes stuck on turbo. It would jerk also at highway speeds when towing sometimes.
Old Nov 29, 2014 | 10:38 AM
jmahle67's Avatar
jmahle67
idk if it helps but turbo has supposedly been upgraded in the past. i just bought truck bout 2 months ago. most of time ive owned it it has sat due to these problems
Old Nov 29, 2014 | 12:46 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yep need some gauges.
Curious about fuel psi and also ICP at those speeds.
Josh
TooHuge
Jun 24, 2016 01:28 PM
Macrosill
Jun 25, 2015 06:24 PM
waumpuscat
Jun 16, 2015 10:51 AM
abowman
107
May 26, 2015 08:00 AM
FDLB350
Dec 24, 2009 12:22 AM
