Feedback carb mixture adjustment?
Old Nov 27, 2014 | 07:13 PM
JayzDaddy's Avatar
JayzDaddy
86 300 1bbl feedback carb
When i tinkered with the carb previously i ran the mixture screw all the way in the backed off 1-1/4 turns. Got it idling very well. But im lacking any hill power in 4th (np435 granny 4) at 35/40mph. I almost think its rich but how is that possible? Every carb i have touched before was full in then back out 1-1/4 or so for base mixture.
Anyway, how did you set yours? No vac gauge available. Air pump removed by po. Doing ignition/carb swap in about 3 months. Just want to get this working well til then.
Btw what is THE go to replacement 1bbl?
Old Nov 27, 2014 | 07:33 PM
Tedster9's Avatar
Tedster9
Idle mixture is for idle. If there's a problem with hills then something else is going on, and not necessarily carburetion.
Old Nov 27, 2014 | 08:16 PM
Gary Lewis's Avatar
Gary Lewis
Pull the codes. There's a how-to in the stickies. The computer will tell what problems there are - if any.
Old Nov 28, 2014 | 09:31 AM
JimsRebel's Avatar
JimsRebel
I use a digital volt meter on the O2 sensor to see the mixture.
I still have a feed back carb and have no plans on swapping it out as there is no noticeable improvements by doing so.
Jim
Old Nov 28, 2014 | 10:23 AM
Franklin2's Avatar
Franklin2
Jim
Did you ever say where you picked up the ported vacuum for the DSII distributor? If you did I have forgotten. I thought this was a problem with the feedback carb?
Old Nov 28, 2014 | 10:54 AM
JimsRebel's Avatar
JimsRebel
I picked the one about 1 inch to the left of the idle adjustment screw, it has the blue tape on it in the picture.
It seemed to react correctly with the timing light and in a best case scenario I can consistently get 17 mpg so I am happy with it. But to be fair my normal is 14-15 mpg.
I think this feed back carb is off an 84 or 85 as it doesn't have a TPS on it.
Jim
Old Nov 28, 2014 | 06:47 PM
JayzDaddy's Avatar
JayzDaddy
Jim, that red hose, whats it connect to? That port on my carb is open. Came that way for me. It doesnt seem to draw vac. Ive just left it open.
Old Nov 28, 2014 | 07:15 PM
Gary Lewis's Avatar
Gary Lewis
I think the red hose is a high-temp material and is used from the hot-air choke to a port in the air horn where it pulls filtered air.
Old Nov 28, 2014 | 07:43 PM
JimsRebel's Avatar
JimsRebel
Here is a good thread.
https://www.ford-trucks.com/forums/1...arter-yfa.html
72tank
Jun 21, 2006 11:59 AM
bassmanh
Apr 13, 2004 07:33 PM
Scrapiron66
Feb 6, 2004 05:54 PM
MANFRED
Nov 10, 2003 08:15 PM
