Hope I didn't come back here too late Steve. My phones this morning were just busty enough to keep away. If you havn't been to the JY yet ya might grab the shift rod off a 78/79 F100/350 also just in case. Since Bumps and Dents take different shift levers on their C4's they may have different leverages,angles,lengths,etc. The 78/79 F100/350 with all three trannys took a specific shift rod. Why,I dunno. Throw of shift lever compared to shift indicator maybe? Need a different than Bump shift rod? Both my slides are messed up right where the part number for this rod is. I think it says D8TZ7326A. "Aprox 19.16" LONG. Note, the bushing/retainer that the shift rod uses to connect it to the steering column lever is E0SZ7341B. Still available from Ford.
I didn't see this post until just a few minutes ago (after I had been to the wrecking yard and back again).
I had already thought about this and I think I have a fairly simple solution, if the stock rod won't work.
I can take some 3/8" diameter rod, the needed length, and thread the ends. From there, I can either install Heim joints at each end or, I can install ball joint rod ends.
