Switching to a C intake
Old Nov 25, 2014 | 08:32 PM
F-250 restorer's Avatar
F-250 restorer
With my Clifford valve cover and DP intake, along with a QJ (or an autolite 4100) it makes it nearly impossible to adjust the idle mixture screws. So I'm sending for a Offy C.
I was wondering if it is possible to coat the inside with something. I've read of problems with the new castings.
Old Nov 26, 2014 | 08:30 AM
trozei's Avatar
trozei
The inside of my C is pretty dang rough, which I find odd considering how buttery smooth the outside is.
Old Nov 26, 2014 | 10:34 AM
fordboy300's Avatar
fordboy300
That's how mine was to I actually took it to the machine shop to get port matched and smoothed out.
Old Nov 26, 2014 | 02:14 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc
A rough surface that far from the valve won't do anything but help keep fuel from condensing/puddling.
I've never seen a coating place that does inside, they can't apply the coating evenly enough. Dunno if coating the outside would do anything other than being easy to clean or looking fancy.
Old Nov 26, 2014 | 07:40 PM
F-250 restorer
BVA--It was just an idea in case I got a poor casting.
Since I'm getting new Harland Sharpe rollers, I'd like to sell my Crane Gold Race roller rockers. They are 1.7 ratio. I ran them for a short time and the improvement in performance was noticeable. I thought I needed p.rod guide plates so I took them off.
I have 12 of them. PM me if interested.
Old Nov 26, 2014 | 08:40 PM
trozei's Avatar
trozei
I'll be cleaning out the inside of my intake as best as possible as I will be using a port injection setup.
Old Nov 27, 2014 | 12:05 PM
F-250 restorer
You ought to post some photos of the system and some documentation or plans. I'm sure other members of the forum would love to see and read about it. Good luck.
Old Nov 27, 2014 | 02:45 PM
trozei's Avatar
trozei
Everything I am doing to both my engine and my truck will be very well documented. I'm even hoping to convince the machine shop to let me film inside their shop.
CoastyAV8R
1978 - 1996 Big Bronco
May 14, 2018 01:09 PM
oneowner83
2011 - 2019 Explorer
Oct 16, 2016 09:30 PM
trozei
25
May 27, 2014 02:00 AM
openexcess
May 30, 2011 09:21 PM
Hydrogen18
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Apr 15, 2005 12:55 AM
