Sponsored by: Real Truck
AirBag Control Module HELP
Old Nov 25, 2014 | 06:50 PM
Cowboy_SW40's Avatar
Cowboy_SW40
I have a 2002 F350 7.3 Powerstroke with approximately 200,000 miles. Recently I have been having an issue with what I am told is my airbag control module heating up to the point it is too warm to touch when I am pulling a heavier load. It is located just under the dash on the center hump. I removed the black plastic cover revealing the module itself in order to determine that indeed is where the heat and smell of hot electrical equipment is originating from. It gets too hot to touch when pulling a heavy load and making the motor work...once I lighten up on it or am not pulling it immediately cools back down. Anyone have any ideas or enlightenment for me? If it is an option I would just disconnect it but I havent yet for fear of creating more of a problem.
Old Dec 3, 2014 | 01:07 PM
akorcovelos's Avatar
akorcovelos
Are you sure its the cause and not a symptom? My buddy had a similar issue caused by a hole in his down pipe, so when he was pulling his camper that area would get too hot to touch.
Mookie's 85
Jun 20, 2017 07:43 PM
uscrpick
1978 - 1996 Big Bronco
Sep 12, 2007 08:33 PM
guy0783
38
Jan 12, 2007 10:17 PM
WALJON
Nov 21, 2004 12:00 PM
RangerRider460
Oct 6, 2004 08:52 PM
