Slow cooling
Old Nov 26, 2014 | 08:39 PM
  #46
tim.moman's Avatar
tim.moman
The problem is the oil around the bearings which get gummed up from the cooking. Many an aircraft turbo worked fine on shutdown and fail on start. But that is not what this thread is about so moving on.
My egt does not like really cold. Way wrong. It will work correct if I unplug and plug in gauge after the cabin warms.
Old Nov 26, 2014 | 08:49 PM
  #47
Money-Pit's Avatar
Money-Pit
I guess we're getting slightly off topic.....but, if EGT's are 500° or less, AND the engine is at idle when shut down, there should not be any issues. Now if someone is pulling hard down the road at say 1100° egts and then truck is turned off/shuts down for whatever reason.....thats not good. We don't hear of many center section failures, mostly vanes sticking or compressor blades getting sandblasted from bad filtration.
Anyway, he has something going on for it to take that long to go from 500 to 400 degree egt's. 1. Gauge accuracy, 2. Overfueling, 3. Lack of air intake/ exhaust restriction would be things I would check.
Old Nov 26, 2014 | 09:57 PM
  #48
04badford's Avatar
04badford
Some things come to mind beside a dirty air filter , have you check your IAT2 sensor? this sensor play's a roll in with the MAF which detects air temps, it also has the exhaust temp and relays info back to the PCM. being in the Intake and lots of soot this sensor will be gummed up. it's located behind the upper fuel bowl .
Old Nov 27, 2014 | 03:04 PM
  #49
Money-Pit's Avatar
Money-Pit
For what it's worth....this is my truck up to temp after a 30 minute drive, pulling in driveway at 400* EGT. Then I take temps of drivers exhaust manifold at egt probe (385°) y-pipe (291°) downpipe (285°) and turbo oil feed line (182°) and turbo center section (210°) After about 4 minutes or filming, the egts were at 300°. Just giving you an idea what another truck acts like.
<iframe width="853" height="480" src="//www.youtube.com/embed/N21GY5DzOxM?rel=0" frameborder="0" allowfullscreen></iframe>
Old Nov 27, 2014 | 10:49 PM
  #50
DieselVol's Avatar
DieselVol
Sorry folks, spent the day losing, finding, bumping, losing, finding, bumping again, the biggest deer I've ever shot. Finally bumped him onto the next farm...lost for good. Bummer. After I got home, I checked the air filter (I have the evil cold air intake, and yes, I am aware of its inherent problems) and found that the filter had popped off of its mount! Hence, no filtering of the intake. I'm guessing that air is not too "cold" coming in there. I brought it in and have cleaned it. Will reinstall tomorrow and see if that affects my cooling time. I suspect it will.
Old Nov 30, 2014 | 08:14 PM
  #51
DieselVol's Avatar
DieselVol
I've watched it closely over 2 days now, through a wide range of temperatures, and it appears to be cooling the way it always did before. I think the filter falling off the mount was the problem. Thanks to all who gave advice.
Old Nov 30, 2014 | 08:26 PM
  #52
tim.moman's Avatar
tim.moman
Great. Who woulda thunk that would cause it. Glad you shared with us.
Old Nov 30, 2014 | 08:47 PM
  #53
04badford's Avatar
04badford
That is great news and thanks for posting the out come , so the Donaldson air box OEM was not snapped together properly is that what I'm hearing?
Old Nov 30, 2014 | 08:58 PM
  #54
DieselVol's Avatar
DieselVol
No, I have the evil AFE cold air intake. This has happened before, where the filter pops off. I've not noticed the cooling problem before, but this is just my second winter with the cold front. I think it was sucking hot air, since it wasn't coming from "out front" like it's supposed to. I'd like to put the stock one back on, but I haven't found it yet.
Old Nov 30, 2014 | 09:05 PM
  #55
04badford's Avatar
04badford
OH I see Aftermarket, give these guys a shout they carry our trucks from time to time or even look in your area
www.riversidesalvage.com or 209-869-3611 ask for Tim ,glad you gother cooling down
Old Nov 30, 2014 | 09:16 PM
  #56
DieselVol's Avatar
DieselVol
Thanks for that. Unfortunately, I still own the '06 truck I used as a donor for my 4wd conversion. I need to check the condition of that box and see if the '06 box will fit my '03.
Fellenz
Nov 14, 2016 09:09 AM
maxine
Jul 21, 2015 12:27 AM
78f3504x4
Jun 16, 2010 03:58 PM
Fordbronco69
Nov 21, 2006 09:41 AM
RSCHAP1
3.0L V6
Mar 14, 2006 04:54 AM
