PCV Valve
Old Nov 25, 2014 | 06:19 PM
daddylee100's Avatar
daddylee100
PCV Valve
Anyone replaced the one behind the EGR/Throttle body?
I seen one on ProDemand that said there was one there and
O'Reilly's tried to sell it to me. It is a thread in type. I already replaced the one in the valve cover. Trying to fix a oil burn prob. Quart every 500 miles or so. Truck has 105,xxx F-350 in sig. Pic is what the thread in one looks like.
Thanks,
Blaine
Old Nov 25, 2014 | 06:59 PM
subford's Avatar
subford
Deleted deleted
Old Nov 26, 2014 | 01:32 PM
daddylee100
That's what I thought, but all the part stores show it and I seen it on ProDemand as my truck having it. Ill try and find a pic showing it.
Old Nov 26, 2014 | 01:34 PM
daddylee100
This was on the hard to find components.
Old Nov 26, 2014 | 01:35 PM
daddylee100
ProDemand is Snap on's equivalent of AllData
Old Nov 26, 2014 | 02:06 PM
subford's Avatar
subford
Your PCV valve should be located back right side in rocker cover.
None of the locations in ProDemand is right.
That does look like the right part, sorry I did not look closer ta the engine.
Old Nov 26, 2014 | 02:27 PM
daddylee100
I replaced that one already but I still burn oil at a pretty fast rate. Maybe 1 quart 400-500 miles. only has 105,000 and does NOT smoke and passed the sniffer with flying colors.
Old Nov 26, 2014 | 02:41 PM
subford's Avatar
subford
That is the only PCV valve that you have.
Old Nov 26, 2014 | 03:02 PM
daddylee100
What do you think could be causing the excessive oil consumption. Motor doesn't feel tired at all. Plenty of power
Old Nov 26, 2014 | 03:19 PM
subford's Avatar
subford
Could be bad valve seals.
If not that it would have to be rings.
The PCV system has nothing to do with the amount of oil a engine burns. The system just takes what ever bypasses the rings back into the intake.
Old Nov 26, 2014 | 05:40 PM
daddylee100
Thanks subford
one4house
1997 - 2003 F150
31
Sep 14, 2023 11:25 AM
maticuno
Modular V10 (6.8l)
Apr 5, 2018 09:48 PM
Fish1980
Mar 14, 2018 06:20 AM
kameronth
Oct 15, 2016 09:25 PM
sealtech101
1997 - 2003 F150
Jan 27, 2011 06:37 PM
