Modular V10 (6.8l)
Two PCV Valves?
Old Apr 5, 2018 | 09:10 PM
maticuno's Avatar
maticuno
Two PCV Valves?
With 180k miles on the clock and a little bit of oil consumption, I'm looking at replacing the PCV valve. Of course I have the one valve on the passenger side valve cover that is plumbed in behind the throttle body. However, when going over all the tubes, it appears there is a second PCV on the driver side valve cover plumbed in before the throttle body. Are these the same part number?
Old Apr 5, 2018 | 09:24 PM
fordmerc's Avatar
fordmerc
The only pcv valve is on the passenger valve cover. The one on the driver side is just a vent tube. If you pull the hose off, it will just be an open hole into the cover.
Old Apr 5, 2018 | 09:48 PM
maticuno's Avatar
maticuno
That makes more sense. Thanks!
kameronth
Oct 15, 2016 09:25 PM
pappy19
Modular V10 (6.8l)
Aug 25, 2012 03:11 PM
Mr Hanky
Modular V10 (6.8l)
Nov 7, 2010 01:35 AM
Mmaxed
Modular V10 (6.8l)
Mar 23, 2008 05:55 PM
the_merlin
1997 - 2003 F150
Sep 11, 2006 02:28 PM
