Alternator options.
Old Nov 25, 2014 | 12:59 PM
brentkhack's Avatar
brentkhack
Alternator options.
I changed out the belt tensioner and idler pulley Saturday. I still have the moaning sound. Is there another vehicle that is a direct bolt on for a higher amperage alternator I can get for an 04 Navigator? Also, how can I tell if I have the 110 or 130?
Old Nov 25, 2014 | 01:30 PM
pdqford's Avatar
pdqford
Are you sure the "moaning" sound is coming from the alternator?
My '02 Navigator has what I call the "moose call" sound every once in a while when the weather is cold. While it is moosing, if I unplug the IAC connector the sound stops immediately.
Old Nov 25, 2014 | 02:37 PM
brentkhack's Avatar
brentkhack
It sounds exactly like turning with low power steering fluid. I know that isn't it because i checked. The sound would change as the rpm's change.
Old Nov 26, 2014 | 12:20 PM
alloro's Avatar
alloro
So what led you to believe the alternator was the cause of the noise?
Old Nov 27, 2014 | 08:25 AM
r2millers's Avatar
r2millers
While running, use an auto stethoscope or long handled screwdriver up to your ear to diagnose where the sound originates.
If alternator, it looks like most auto parts only stock a 130/135 amp unit. There are 110 amp units that can fit for about the same price but usually special order.
No reason not to get the larger amp unit.
With sound changing with rpm's, it's probably not far from where you're searching.
Old Dec 1, 2014 | 05:49 PM
brentkhack's Avatar
brentkhack
Well I put in a new alternator and the noise was still there. While I had things apart I put my head closer to the front of the engine and the noise was really loud on the drivers side. So it was my steering pump. I replaced that and the horrible noise is gone. Things are still not 100% perfect but I will start a new thread on that. Thanks.
Old Dec 8, 2014 | 06:45 PM
r2millers's Avatar
r2millers
I'm glad to hear you got it fixed.
I never quite understand why so many ask for advise and then decide to not use it. The 3.99 item below could have saved you a few bucks.
Mechanic's Stethoscope
Probably needed a new alternator anyways.
Old Dec 9, 2014 | 02:47 AM
alloro's Avatar
alloro
It's called, denial!
Old Dec 9, 2014 | 07:48 PM
brentkhack's Avatar
brentkhack
I always appreciate the help here. I dont mind changing a few extra things out right now. It has 127k miles on it and my wife will be driving it for a few months. I rather things not go out during that time.
P.S. changing the steering pump was horrible.
Old Dec 10, 2014 | 01:26 AM
alloro's Avatar
alloro
Did you do it from the top or from the bottom?
Old Dec 10, 2014 | 08:26 AM
brentkhack's Avatar
brentkhack
My father-in-law has a salvage yard so I was able to use his lift. I unscrewed the high pressure line, and two bottom PS pump bolts from the bottom. From the top I was able to get the third bolt and unclamp the low pressure line and pull the whole unit with pulley from the top. I did read that pulling the tire and inner fender liner was another option and I think would have been easier.
Old Dec 10, 2014 | 09:53 AM
alloro's Avatar
alloro
Yes, much easier. That allows you to reach the pump from the side with very little in your way. BTW, nice going with the lift, not much beats having access to one of those.
GermanMike
Jan 9, 2012 09:24 PM
pnaffziger
May 25, 2010 07:34 PM
No_BS
Electrical Systems/Wiring
May 13, 2005 08:02 AM
