steering shaft
Old Nov 25, 2014 | 04:44 AM
gretchen5150's Avatar
gretchen5150
steering shaft
When im driving my 78 f150 or even just parked with the truck on turning the wheel is ok but its not smooth when i turn. Ill turn the wheel to the right an can feel it like lock in a sense but its not locked itll stay in that postion if i just let go but i can physically turn the wheel with little pressure but at a certain point of turning i can feel it click. When i go to the left its easier but has some play in the wheel can anybody help me decifer this problem
Old Nov 25, 2014 | 06:35 AM
co425's Avatar
co425
Is your truck 2 wheel drive or 4?
Old Nov 25, 2014 | 08:14 AM
jim collins's Avatar
jim collins
May have a bad coupling joint right before it connects to the steering gear, i would check that for sure.
Old Nov 25, 2014 | 08:48 AM
mikerogers56's Avatar
mikerogers56
I had the king pins seize up on my first 78. It started with symptoms similar to what you're describing.
Old Nov 25, 2014 | 10:05 AM
gretchen5150
Could you elaborate so i can see what your talking about?
Old Nov 25, 2014 | 10:31 AM
Sandgnat's Avatar
Sandgnat
I had a similar issue with mine. It turned out to be a bad u-joint on the intermediate shaft where it connects to the steering column. I replaced the whole steering shaft with one from Bronco Graveyard, smooth steering now.
Old Nov 25, 2014 | 10:34 AM
gretchen5150
Can i see a picture or something of what i should look at causw i cant afford a whole steering shaft right now at the prices im seeing could i buy a new u joint for it
Old Nov 25, 2014 | 10:51 AM
Sandgnat's Avatar
Sandgnat
They do make just a u-joint, but my factory joint was welded on the shaft. You probably could cut it off and make the replacement joint work. They sell just the joint too at Bronco Graveyard's website. Open you hood and look at the steering shaft couples to the steering column. You will see a u-joint. You can remove your shaft from the truck and move the u-joint with your hand if it is tight in any direction then it needs replacing. It is not hard to do.
scottjbear
Jan 7, 2012 04:29 PM
nothercrash
Oct 9, 2010 04:51 PM
4x4Man09
Dec 3, 2009 10:38 AM
3004speed
Feb 22, 2009 08:34 AM
lawdogkms
Oct 14, 2003 09:48 AM
