Sponsored by: Auxito
4.6 oil pump
Old Nov 24, 2014 | 11:00 PM
jasonfloorguy's Avatar
jasonfloorguy
4.6 oil pump
I have had a noise in the front of the engine of my 2002 f150 4.6 for about 2 weeks. On my way home my oil light came on made a knocking noise and shut off. The engine would not start back starter would engage but not turn motor it was seized. i called a tow truck and had it towed home. The next day just out of curiosity I tried to start it. It fired up ran and built oil pressure. If the oil pump froze will that make it . Can the oil pump make the engine act seized up?
Old Nov 25, 2014 | 12:05 PM
Bluegrass 7's Avatar
Bluegrass 7
Is the oil level up on the dip stick where it belongs?
If you ran on no oil on the stick you likely got serious engine damage by running too low on oil.
That can freeze (burn) fast rod and crank bearings, starve the cylinders of lube and stop the motor.
When the motor cools it sometimes is broken free by the starter after the parts shrink .
You must understand that while running at speed the oil in the pan is less because a lot is circulating 'upstairs' in the top of the motor so the pump could run out if there is nothing left to pick up.
As of now you don't know how serious it is without a lot of work or taking a chance and continue using the truck until the motor gives up again, then it replacement time.
The oil pump itself is the last part I would blame for what has happened unless the pickup tube broke off or totally plugged up. You still have to remove the pan to find out..
Good luck.
Old Nov 25, 2014 | 03:37 PM
jasonfloorguy
It was full of oil. It is making a noise like the timing chain slapping. I plan on taking apart the front of the motor and inspect oil pump and timing chains.
Old Nov 28, 2014 | 05:51 PM
craftsmangary's Avatar
craftsmangary
When you loose oil pressure on a OHC engine usually the cam seizes in the head first, then sometimes when they cool down the engine will crank again. Usually the engine needs rebuilt to repair it.
jkedward
Jun 30, 2015 12:06 PM
1stonracday
2004 - 2008 F150
Oct 24, 2014 10:00 AM
newbe-rebuilder
Sep 8, 2008 02:09 PM
bigbadford78
29
Dec 5, 2005 12:01 AM
maximumhorsepower
Sep 9, 2004 10:12 PM
