Sponsored by: Real Truck
Need help!!
Old Nov 23, 2014 | 05:02 PM
wisford350's Avatar
wisford350
Need help!!
I have a 96 f350 that I just replaced the batteries on and now when I go to start it does not hardly turn over. Starter just barely turns motor over and definitely not fast enough to start truck. Battery connections are tight and starter was replaced about 4 months ago. Any help would be appreciated.
Old Nov 23, 2014 | 05:08 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Is this the same as it was doing before replacing the batteries?
Were the cable ends corroded?
Old Nov 23, 2014 | 05:17 PM
wisford350's Avatar
wisford350
Cable ends were a little corroded but I cleaned them up before replacing the batteries. Old batteries went bad but it would start fine before they went
Old Nov 23, 2014 | 07:13 PM
Ltngdrvr's Avatar
Ltngdrvr
Top Answer: 5
Well, those old battery cables could be corroded down inside.
I would also get the batteries and charging system tested.
Will it jump start?
Old Nov 23, 2014 | 10:23 PM
happscrap's Avatar
happscrap
Test the alternator.
99F350bigorange
Jul 9, 2011 04:04 PM
roushcm
Dec 1, 2010 12:15 AM
fd1109
Feb 14, 2008 04:01 PM
79beater
Jan 25, 2007 10:11 PM
DaMole
Mar 1, 2006 08:44 PM
