Starter ,batteries or cables ??
Old Feb 13, 2008 | 10:57 AM
fd1109's Avatar
fd1109
My truck has been cranking slow and the other morning at 25 degress and plugged in all night it cranked over 3 times and that was it ! Glow plugs are fine , bateries check out ok on load test and hydro test on cells , cables had a little bit of corode but nothing that was that bad , batteries were replaced 2- years ago with Interstates , new heavy duty gpr , new starter 2 1/2 yeats ago 150,000 miles on truck . Next thing to do is take voltage drops on cable while cranking . The other morning when it would'nt start , I hooked it up to a heavy duty battery charger in the boost mode for about 2 minutes and it started right up with no trouble or smoke . What am I missing and are there certain areas that are a reoccuring problem ?? I don't want to jump the gun and start throwing staters cables or batteries at it .. Thanks
Old Feb 13, 2008 | 11:29 AM
F350-6's Avatar
F350-6
Don't forget to look for corrosion on the other ends of the battery cables. Did you disconnect the batteries and load test them separately? It sure sounds like you've got a weak battery.
Old Feb 13, 2008 | 11:47 AM
ggirten's Avatar
ggirten
I agree. I had a week battery. Turned over fine, but would not charge. Check them together and it looks OK.
Old Feb 13, 2008 | 09:21 PM
fd1109's Avatar
fd1109
Tested batteries seperate and are clean .
Old Feb 13, 2008 | 09:31 PM
medhvac's Avatar
medhvac
could be and altenator problem have them checked out! if ya have 2 of them!
Old Feb 14, 2008 | 06:58 AM
fd1109's Avatar
fd1109
How do you disable the starting circuit so you can crank the engine over without it starting ? I need to take voltage drop readings on the battery cables and don't want it to start ?
Old Feb 14, 2008 | 07:07 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Unplug the CPS.
Old Feb 14, 2008 | 04:01 PM
fd1109's Avatar
fd1109
Thanks Kris
