The MODBUG
Old Nov 24, 2014 | 08:42 AM
Tugly's Avatar
Tugly
NGS? You have it covered. More concept "art":
Old Nov 24, 2014 | 10:07 AM
Smokiesman's Avatar
Smokiesman
I second the steering wheel!!!
Smokie
Old Nov 24, 2014 | 04:22 PM
tonym17's Avatar
tonym17
Ordered the AIS at 9 this morning and had it at 2pm...10 min job....Next change the green coolant out..
Old Nov 24, 2014 | 05:39 PM
F350-6's Avatar
F350-6
Looks good. I think that's the first time I've seen someone switch out the stock headlight switch.
Old Nov 25, 2014 | 01:10 AM
scotttahoe's Avatar
scotttahoe
Here is a close up for you. Couldn't have a headlight switch not matching the others.
Old Nov 25, 2014 | 01:15 AM
scotttahoe's Avatar
scotttahoe
This is one purty truck! I got the honor to sit behind the wheel and go for a spin and you need to cary a set of tooth picks to pick your eyeballs back into place from the back of your head!
Old Dec 21, 2014 | 05:46 PM
tonym17's Avatar
tonym17
After waiting a few couple weeks for my emblem to get here it came unpainted....The I should be red...
Took it to the local powder coating and was a no go....
So I searched a bit and came up with resin with acrylic enamel red to color it then used a syringe to apply it
Old Dec 21, 2014 | 06:36 PM
Bonanza35's Avatar
Bonanza35
I like it. Good job.
Old Dec 21, 2014 | 06:37 PM
F350-6's Avatar
F350-6
Looks good. Are you going to upgrade to the 02 clear headlights?
Old Dec 21, 2014 | 06:50 PM
tonym17's Avatar
tonym17
not anytime soon....need to address the rocker panels ASAP, drivers side has a hole in it
Old Dec 21, 2014 | 06:55 PM
BadDogKuzz's Avatar
BadDogKuzz
Tony the emblem turned out sweet !! Now is your truck black? If so next I would go with smoked cab lights and blacked out headlights. It would round off the front end. Here is mine I wish I would have done the black H/D headlights.
Old Dec 21, 2014 | 07:03 PM
tonym17's Avatar
tonym17
nope its Dark Tourmaline Metallic (green)
Old Dec 21, 2014 | 07:39 PM
  #28
BadDogKuzz's Avatar
BadDogKuzz
That is a good looking truck! I have always liked that color but they are hard to find and I have never even seen a dually that color. With that color you could go either way when you get around to doing the lights clear or black. Heck just about everything would look good on that truck. By the way how did you get rust down south there?? Or did you get your truck from up here in the arm pit of the nation?
Old Dec 21, 2014 | 07:57 PM
  #29
tonym17's Avatar
tonym17
was a 1 owner Maryland truck (Annapolis) 103k on it... the rockers are the only thing I see that are bad and its only a small part under the rear door right next to where its spot welded....oil pan and frame have been tended to and look great...
Old Dec 21, 2014 | 09:31 PM
  #30
rcgtsport's Avatar
rcgtsport
nice truck and color! i got rot hole in same place with cab corners starting to bubble. wonder if a leaking third brake light caused it? mods i like results of frx,hpx,hutch harpoon mod.
