1948 F-3 Rat Rod Project
I'm new here...
My friend, Randy, and I recently acquired a 1948 F-3 that had been sitting for many years with the intention of turning it into a "Rat" rod. This is going to be a budget project (as much as possible).
We are well underway at this point... We stripped the truck down to the frame, which is in remarkably good condition. The bodywork is also in pretty fair shape, with just some minor rust areas where the metal was double-layered for additional strength.
We also acquired a 2008 Crown Vic. We intend to use the front suspension and engine/transmission in the 'rod'. The rear suspension will be the IRS from a mid-90's Lincoln.
When I figure out how to do it, I'll post some photos of the work in progress.
Also, we'll have an inventory of mechanical parts from the F-3 that will be available if anyone needs anything.
Welcome to FTE! Posting pictures is easy. Just click on the mountain icon and either past a link in or drag and drop from your pc.
So, what do you mean by "Rat" rod. Around here we think of someone making an unsafe trash heap when rat rod is mentioned. Safety for the driver and other people on the road are of utmost importance to us here. We also like to see people drive the heck out of them.
Other than that we have all sorts of different styles and modifications.
I see you are from Canada, we have quite a few of our Northern brethren on here.
Now post those pics!
Yeah, "rat rod" tends to raise some hackles around here for some. I think it's because they have seen some really marginal, unsafe builds. Most that I've seen have been well done and really unique. You can always call it a "vintage" or "traditional" hot rod.
Anyway. welcome. Can't wait to see some pic's.
Hey Phil,
Welcome Aboard! The easiest way to post pics is to join the site. It's $20/yr & that get's rid of most of the annoying pop-up advertisements & allows you to post pics directly from your hard drive. You get a little paper clip icon to click.
Good luck up there in Canada! Think hotrod or restomod Phil - sounds so much nicer than ratrod. Post pics when you get a chance.
Ben in Austin
1950 F1 (Hotrod/Restomod)
Ben in Austin
I know what you're trying to say, but what ratrod means to me, (and what I think the word has evolved to mean,) is a patina-finished vehicle or one cobbled up with parts from multiple different vehicles. However, as I understand, it originated from people who wanted a hot rod but didn't have much cash, so they grabbed anything they had, or had to pay very little for, and welded and chopped until it, (kind of,) fit. This usually ended up in a very unsafe car, (think big block on stock model A chassis, steering, and brakes.) This then became popular with the people of slightly more sound mind who wanted that "ratty" look with better build quality and safety. I've seen some "rat-rods" with incredible craftsmanship and ingenuity, and some that scare me to think about being anywhere near while it's driving around.
In the beginning of the Hot Rod era there were no "kits", no ready made aftermarket products to fit just about any combination of parts, and no "rules" other than their own rules. As long as a build is safe for the rest of the road I don't have a problem with what someone else wants to build - even if I might think it is ugly and a waste of good sheet metal
Here's the truck as we received it after sitting in a field for several years.
Just a good wash improved the looks a lot!
This is the donor car, a 2008 Crown Vic. We'll be using the front suspension, engine, trans, and possibly a few other bits and pieces (fuel tank?).
Once we got the truck on the hoist and had a look at the frame we were very happy. It looks very solid! No signs of any damage at all!
