Noise in rear gas tank
I have a noise coming from the rear gas tank on my '92 F150. A knocking sound when the gas moves something inside the tank. When the tank is more than 1/4 full it is a lot louder due to the echo from the gas. I can still hear it when the tank is empty, or close to it but it is a different sound like metal knocking on metal. Any ideas? I have seen what it takes to remove the tank and really don't want to do that without knowing first if it I need to remove it and open it up.
I have checked everything I can think of. It sounds exactly like something is loose. I have looked, as well as 5 other people. Lifted the truck, run in place, etc. I now noticed that it changes when the rear tank is empty. That's what makes me think it is in the tank. No problems with gas supply using either tank.
i dont know whether these trucks have an anti-siphon screen in the filler necks but a few years back a friend of mine found a hose in his gas tank (not f-series) ... whether by accident or design someone had left a siphon hose in the tank. it didnt make any noise at all but it sporadically interfered with the fuel pump . just sayin' there could be a foreign object in there.
FLgargoyle
15
04-19-2007 07:41 PM
