Sponsored by: Auxito
Need some help..
Old Nov 21, 2014 | 02:49 AM
Finch1997's Avatar
Finch1997
Need some help..
In my quest to figure out why my 4x4 is not working i found an unplugged wire above my differential, i cannot for the life of my find where the dang thing plugs in. Right now, im having issues with rough idle at slow down or coming to a stop where it will idle down to 500 rpms and die. Only having issues when below 40 degrees. Alternator tested good and has new battery. Could this unplugged wire be the reason? Truck is a 1997 f150 4.6 v8 vin W
Old Nov 21, 2014 | 07:43 AM
Spotty's Avatar
Spotty
How many wires and what does the connector look like? Does your A/C click on when on defrost? Lot of cold weather idle issues are the IAC valve up on the throttle body. My 98 would act up when cold. I would tap it with the handle end of a big screwdriver and the idle would come up and smooth out.
Old Nov 21, 2014 | 06:08 PM
projectSHO89's Avatar
projectSHO89
That's either a vacuum problem or a sticking IAC valve.
Chief Mike
1997 - 2003 F150
Jan 22, 2011 09:18 AM
BamaRebel
1997 - 2003 F150
Oct 24, 2006 07:50 PM
craneman74
Modular V8 (4.6L, 5.4L)
Oct 10, 2004 10:31 PM
