Truck shutting down on me.
Old 11-20-2014, 03:23 PM
Mango11b's Avatar
Mango11b
Mango11b is offline
I got a 04 f150 5.4 and ive ran into trouble and im not sure whats the problem. So im up in the snow right now and every time i start to go threw some thick snow my tires start to spin out and my truck shuts off on me. It only does that when i really give it some gas and my tires are spinning. Could it be the throttle body?
Old 11-20-2014, 03:32 PM
ToMang07's Avatar
ToMang07
ToMang07 is offline
The truck has a Gryphon programmer, and is popping codes:
P0553 (P0553 Ford - Power Steering Pressure Sensor Circuit High Input)
P2105 (P2105 - Throttle Actuator Control System - Forced Engine Shutdown)
P2106 (P2106 Ford - Throttle Actuator Control System - Forced Limited Power)
Old 11-21-2014, 06:03 AM
fordiesel69's Avatar
fordiesel69
fordiesel69 is offline
04 could have cable throttle or electronic throttle.
1. Verify the air box is properly sealing and alsop that your air filter is not iced over, or collapsed. Also check the air inlet on the air box to make sure it is not frozen over.
2. Remove the zip tube from the throttle body, and with the key on, have someone press the gas and you watch for smooth opening and closing of the flap.
3. Clean the flap until it is spotless. I use air intake cleaner. You could use carb sleaner too.
If still getting the codes and stalling, it is time for a new throttle body.
Old 11-21-2014, 11:29 AM
Mango11b's Avatar
Mango11b
Mango11b is offline
Thanks, ill check it out.
Old 12-18-2014, 11:40 PM
Mango11b's Avatar
Mango11b
Mango11b is offline
Just thought I'd mention I have a CAI and the filter is clean.
Codes still pop up, but the truck only stalls out now when you spin the tires and rev the engine up. Don't know why.
Old 12-18-2014, 11:42 PM
Mango11b's Avatar
Mango11b
Mango11b is offline
I have been using my gryphon programmer and my brother's Laptop/AE to pull codes. The Gyrphon had PHP's "Custom" tune on it.
Old 12-18-2014, 11:44 PM
Mango11b's Avatar
Mango11b
Mango11b is offline
Only other mod is a cat-back dual exhaust with dual Flowmasters and 295/65R18 Duratracs.
Old 12-24-2014, 06:00 PM
Mango11b's Avatar
Mango11b
Mango11b is offline
so my brother and i took apart my whole CAI and throttle body and cleaned it. It really needed a good cleaning. My trucks no longer shutting down on me and is running much better! Thanks for the help.
Mango11b
Modular V8 (4.6L, 5.4L)
11-20-2014 03:30 PM
clark714x4
12-07-2004 05:48 PM
brooknbrown
2004 - 2008 F150
05-22-2004 12:09 AM
73highboy4x4
1997-2006 Expedition & Navigator
11-09-2003 12:18 AM
91FordBaja
17
01-01-2003 12:27 PM
Quick Reply: Truck shutting down on me.
