49 F100 Rat Rod questions
Wanting to start my first build and On my local Craigslist I found a great 49 f100 cab and hood on a model a frame but don't know if it's something good to start with. The roof has been cut from the truck which isn't a big deal. Only wants $300 for all of it. Currently am doing a cv swap in my 63 f100 and didn't know if I could use the straight axle from that on the front of this.
Hood is from a 51. Thre's not even $300 worth in scrap. I'd stay away. Save the $300 and use it to buy something better that actually resembles a truck and will give you a better starting point. Good rule of thumb is the more you spend up front, the less you will spend later.
To answer your question about the '63 axle, I think you'll find it is quite a bit wider than this "truck".
tacson
61
02-17-2008 05:40 PM
