I have a 2001 F250 4x4 cc Power Stroke With automatic transmission. I have a question: the "cooling" lines from the transmission go to the cooler in the bottom of the radiator, one line simply comes from the trans. and goes into the cooler the other line comes out of the other side of the radiator cooler and disapears into the front of the radiator area and then comes back out and back to the transmission. short of taking out the grill and no telling what else, I can not see where this line goes. I do not see another cooler. this truck is all original. Can someone cast some light on where this line may go. less important, which line is the return line..the one out of the front of the trany or the one in the back. Thank you for any help.....charlie
