Yea, you could be right. Or maybe it was a late production 71 and was simply registered as a 72? I bought it from the original owner and he didn't modify it. I guess it's just one of the older Ford mysteries.
I don't know when it was made. Sadly I sold it many years ago. I've owned two bumpsides in my life and enjoyed both of them. A 70 F100 4X4 and my F250 Camper Special. I bought my F250 with almost 60,000 miles on it. It had a 360 and a 4 speed with the granny low. When I finally got rid of it, it had just rolled over 200,000 miles. Stupid me, I didn't know what I had back then.
Man that granny low was soooo handy out in the hay fields. Even when pulling a hay wagon half full I could still jump out of the truck and help throw the bales on the wagon and then jump back in the truck without stalling.
When I sell my bike next year I'm going to shop for another bumpside. F250 4X4 Crew Cab and, I hope, a short box. I don't care what year and if it doesn't have the same grill as yours I'll replace it. Hell, while I'm dreaming of the perfect truck I might as well wish for a blue truck with a 300 I6 too.
Granny low gears are awesome for hauling stuff and doing things like you mentioned. My brother has a bronco with 4speed granny. Pair that with low-range 4wd and you've got some serious gear reduction!!!
2X 351. Back in 1979 I had a new Bronco. 351M,granny,3.50 gears,and a NP205. With T/C in low and in granny gear the engine was about to blow up at about 4-5 MPH as I recall.
I don't know what my rear diff gearing was but I think 4 or 5 mph was about max in granny low. I never used it except when starting out with HEAVY loads or, as mentioned, haying. I didn't have a tach but based on the sound of the engine that's about all I had for speed in low. I also only got about 9 mpg too
I know in our super duty with the 4r100, 1st gear is 2.4:1, transfer case is 2.8:1, and axles are 3.73. That makes for a 25:1 crawl ratio. With the big ol' 7.3 diesel, you have to step on the brakes firmly to hold it back.
351. You reminded me of that old Ford commercial where they showed a Ford truck pulling a train. I think it was a Dent. Maybe Bump.
Love the Clevelands! At 18, sold my 72 351 4v Torino to a wrecking yard (just like one in the movie except steelies w and whitewalls),had no idea the difference in the 2 and 4V motors were except carbs..car was trashed and went thru front tires once a month..totally ragged..went back later that year and nothing left but the hull! Thought it was a neat old car,but bought for a cheap old work beater...shure wish I had that motor back!!
Lots of people don't know what the Cleveland's really are. They think they are crap because they were only around for a few years. Little do they know. Massive ports, canted valves, closed chamber quench heads. They were factory production race engines!
They do get good MPG. Mine gets 15-16 on the highway in my truck. And that's boggin along at 1500rpm/65mph. I'm switching to 4.11 gears to bring rpm up about 500. 2000@ 65 should lessen the load and improve MPG and power.
