351 Id
Old Jul 18, 2007 | 02:24 PM
Dirigo's Avatar
Dirigo
351 Id
Can anyone tell from this photo which 351 this is?
Old Jul 18, 2007 | 03:08 PM
HemiEater's Avatar
HemiEater
looks like it came out of a truck...not even sure if it's a 351 or not.
Old Jul 18, 2007 | 03:55 PM
Dirigo's Avatar
Dirigo
I thought there may have been some distinguishing characteristic that someone could have noticed, because i dont know the difference in looks between the three.
Old Jul 18, 2007 | 04:22 PM
HemiEater's Avatar
HemiEater
it's a W for sure.......if it's a 351
Old Jul 18, 2007 | 08:59 PM
Beanscoot's Avatar
Beanscoot
Yes, if the choice is between 351C, 351M and 351W this engine must be the last. The C and M engines have quite different cylinder heads with the exhaust face inline with the angle of the block's "V".
The 351C was discontinued in 1974, the 351M was discontinued in the early '80s.
Old Jul 23, 2007 | 08:23 PM
raerjim's Avatar
raerjim
How many valve cover bolts? Does the upper radiator hose go to the intake manifold?
Old Jul 23, 2007 | 08:30 PM
gulfcrestinc's Avatar
gulfcrestinc
351w has the thermostat housing is above the water pump a good bit. its high enough to get a socket straighton it from the front. its a winsor motor looks like out of a van.
Old Jul 23, 2007 | 09:03 PM
Conanski's Avatar
Conanski
I'm thinking it's one of the Windsors as well, it has the same oil dipstick my motor has. But it could easily be a 302 or 351, hard to say with all the crap/accessories in the way. You can measure the deck height and know for sure. It will be 9.5" from crank centerline to head gasket on a 351, 8.2" on a 302.
Old Jul 23, 2007 | 09:19 PM
kc5gxl's Avatar
kc5gxl
It is a Windsor engine if it is a 351. The way to tell if it is a 302 or 351 is to spread your hand across the intake manifold from head to head. If it is a 302, your fingers will just about touch both heads. If it is a 351, there will be about a 1 1/2" gap to one head.
Dan Harriman
Orange, Texas
Old Jul 23, 2007 | 09:53 PM
Beanscoot's Avatar
Beanscoot
That's probably the handiest tip I've heard of to differentiate the two motors, kc5gxl.
Old Jul 23, 2007 | 10:06 PM
fmc400's Avatar
fmc400
MSEE
Looks a little small to me to be a 351, I'd guess a 302.
fox fan
Ford Truck Parts for Sale
Aug 22, 2013 09:46 PM
robjs111
May 11, 2013 07:08 PM
robjs111
Mar 27, 2013 01:39 PM
bob_351
Feb 22, 2010 02:47 AM
preppypyro
31
Jan 31, 2010 09:11 AM
