Guess which cop I had to replace
Old Nov 19, 2014 | 08:13 PM
wtroger's Avatar
wtroger
The absolute worst one on a 98 expy to get to and replace. That's right number 3. The engineers that came up with this design should have to spend eternity changing these every day all day. Every heater hose setting on top of it. Plus that stupid power center. I did go ahead and Change the plug while it was at it.
Old Nov 20, 2014 | 08:14 AM
timbersteel's Avatar
timbersteel
I feel your pain. I had the same one fail 14 miles outside of Branson on our honeymoon this year, 200 miles from home. Luckily I found an O'Reillys and got it changed in the parking lot. It was expen$ive. I learned to keep spares on hand. Luckily I changed plugs last year.
Old Nov 20, 2014 | 09:12 AM
SilverSS's Avatar
SilverSS
#4 will be next! lol
Old Nov 20, 2014 | 07:21 PM
wtroger's Avatar
wtroger
Already done that one. It a lot easier in my mind then that #3. Not that it isn't a pita.
Old Nov 21, 2014 | 10:07 AM
r2millers's Avatar
r2millers
I thought the #3 was a piece of cake compared to the #4. Not sure what made the #3 so tough?
I take a few bungees or rope and tie back the heater hose lines to get easier access to both 3 and 4.
Try #8, you have to pull the fuel rail out slightly to access, not to mention, doing everything by feel.
I've changed out COP's on an F-250 V10 much easier, even though they set back further due to more space.
Old Nov 22, 2014 | 09:00 AM
flyboy2610's Avatar
flyboy2610
AS someone who is considering perhaps purchasing an Expedition of this vintage next March or April, may I ask: What do you mean by COP?
Old Nov 22, 2014 | 11:49 AM
SilverSS's Avatar
SilverSS
coil on plug. The coil packs on each cylinder.
Old Nov 22, 2014 | 03:16 PM
r2millers's Avatar
r2millers
Yes, instead of a distributor and plug wires, for that engine, each cylinder has a coil pak that works specifically for that cylinder. It's located on top of the engine and drops down on top of the plug.
Here's four of them below, 8 per engine.
Old Nov 23, 2014 | 07:54 AM
flyboy2610's Avatar
flyboy2610
I see, said the blind man, as he picked up the hammer and saw.
I've never seen that type of setup before. I guess the good old fashioned tried and true way of doing things isn't good enough anymore.
How do you know when one those goes out? I would imagine you'd get a real stumble or misfire.
Old Nov 23, 2014 | 09:14 AM
wtroger's Avatar
wtroger
You will feel a miss and usually get cel light with a 30x code the x being the cylinder experiencing the miss fire
78Explorer
Dec 26, 2019 01:40 PM
Coastie6
Modular V10 (6.8l)
15
Jan 1, 2015 07:03 AM
drastic
Jul 15, 2012 09:31 AM
SnowHiker
1997 - 2003 F150
20
Feb 1, 2008 11:29 PM
KeithE524
May 19, 2004 11:38 AM
