wally world need help
Old Nov 18, 2014 | 05:59 PM
wallyworld's Avatar
wallyworld
i,ve a 71 f-100 that changing to disc out of 78 .also will be trying to put the p/booster off of 78 too. also thep/s too. have been told that will have to change steering column or cut. this is a 3 on the tree. any help !
Old Nov 18, 2014 | 07:22 PM
trozei's Avatar
trozei
Power steering and manual steering columns are different lengths, and I believe the 3-on-tree P/S column is the hardest one to find. Good luck!
Old Nov 18, 2014 | 08:11 PM
HIO Silver's Avatar
HIO Silver
I put 78 discs and power brakes on my '70. You'll prolly need a PS-specific pitman arm due to an engineering change which revised the angle of its head. Is your 71 "late" or "early"? Build number M00000 or higher or prior to M00000, respectively?
More info here: Steering/Suspension Component Variations - FORDification.com
Another possible change is the brake hose to frame clip. Read all about it in my build thread: https://www.ford-trucks.com/forums/1...ide-build.html
Good luck with finding steering column.
Old Nov 19, 2014 | 03:34 PM
JEFFFAFA's Avatar
JEFFFAFA
CONTACT Ford_Six:
<TABLE id=post14793920 class=tborder border=0 cellSpacing=1 cellPadding=6 width="100%" align=center><TBODY><TR><TD style="PADDING-BOTTOM: 0px; PADDING-LEFT: 0px; PADDING-RIGHT: 0px; PADDING-TOP: 0px" class=alt2><TABLE border=0 cellSpacing=6 cellPadding=0 width="100%"><TBODY><TR><TD class=alt2></TD><TD noWrap>Ford_Six ******** type=text/javascript> vbmenu_register("postmenu_14793920", true); *********>
</TD><TD width="100%"> </TD><TD vAlign=top noWrap>Join Date: Oct 2002
</TD></TR></TBODY></TABLE><!-- / user info --></TD></TR><TR><TD id=td_post_14793920 class=alt1><!-- message, attachments, sig --><!-- message -->Sitting in yank a part in Poulsbo WA, the shifter is missing but the column is tight.
This is only the second one I've ever seen. If you are doing a PS swap on a three speed truck, I can pull and ship the column.
<!-- / message --><!-- attachments -->
<!-- / attachments --><!-- sig -->__________________
Jared
Real trucks have the key on the left
FTE Guidelines
Old Nov 19, 2014 | 04:51 PM
wallyworld's Avatar
wallyworld
71ford
mine is early.
Old Nov 19, 2014 | 05:04 PM
wallyworld's Avatar
wallyworld
read the info,thanks for the help. also ain,t make up mind on steering column ,may use 78 auto and go floor shift.
Old Nov 19, 2014 | 06:22 PM
Ford_Six's Avatar
Ford_Six
Yup, that column is now part of 12ozD's build.
Here is the article I wrote on the swap, it is possible to cut down your column but it's a pain and not something I would recommend for someone who is not a professional welder.
Power Steering & Disk Brakes 2wd 65-72 - Ford Trucks
This does also move the column up a bit, so the linkage may be different.
If you are going auto, then a 78-79 tilt column is the way to go. I'm trying to find my own rare 78-79 4x4 floor shift tilt column, I haven't even seen one of those trucks. I may end up with an aftermarket or rework the 80s one I have.
Old Nov 19, 2014 | 07:30 PM
HIO Silver's Avatar
HIO Silver
2x...I've been looking for over four years and have yet to luck upon one.
Hen's teeth...
Old Nov 19, 2014 | 08:41 PM
willowbilly3's Avatar
willowbilly3
I've never actually seen a 3 speed power steering column and I owned and scrounged parts from literally hundreds of 67-72s. You could always use the bendix ps box that doesn't require any column change.
Old Nov 20, 2014 | 07:39 PM
Ford_Six's Avatar
Ford_Six
I've seen two now, the first was a 70 parts truck that was completely trashed, it rode around on bad cab mounts until it not only destroyed the lower bearing but severely wore the shift tube as well. I let that column go with the truck when it was scrapped. It was oddly optioned, a 360 with power steering, column shift, and full Ranger package with a cargo light and upholstered door panels, white cab roof, and full trim. You'd think if someone payed for all that stuff they'd get a four speed or automatic. The truck was a complete mess unfortunately so I just pulled some select bits off.
86F250 460
Apr 16, 2018 07:07 AM
Brian1971f100
52
Feb 28, 2017 05:46 PM
mismith
Ford Truck Parts for Sale
Mar 7, 2015 11:46 AM
effie_man
Feb 13, 2008 11:03 PM
