Door Access Panel screws..
Old 11-17-2014, 03:33 PM
jmf66's Avatar
jmf66
jmf66 is offline
I'm looking for the 16 screws and j-nuts that attach the door access panels on my '66. Surely I can do better than $57 at LMC Truck!! Anyone know what size these might be?
Old 11-17-2014, 04:54 PM
schoo's Avatar
schoo
schoo is offline
I used ss screws from HF used my buffer and polished them up(screwed in a block of wood)the same with my dash screws sun visor and head liner
Old 11-17-2014, 05:00 PM
SuperSabre's Avatar
SuperSabre
SuperSabre is offline
If they don't have to be factory, take a sample down to ACE Hardware, which is what I did. HF like schoo did would be cheaper, though.
Old 11-17-2014, 05:04 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
I'd have to check at home but I know I bought my screws at ACE Hardware. The screws themselves are SS pan heads and think there are #10 at minimum. Didn't need the j nut as I wasn't missing any but just wanted new screws.
Old 11-17-2014, 05:13 PM
resonateur's Avatar
resonateur
resonateur is online now
Jerry:
If you're not in a hurry, I have a set (used original) that I can send you for the price of postage. Otherwise most of your nut/bolt stores or hardware stores will have the J-nuts and sheet metal screws. You're welcome to my old ones, they just won't look as good as new hardware.
Old 11-17-2014, 06:31 PM
johnmel59's Avatar
johnmel59
johnmel59 is offline
I bought my screws and "j" nuts at Lowes. They have some automotive fasteners on the hardware aisle.
Old 11-17-2014, 07:21 PM
TA455HO's Avatar
TA455HO
TA455HO is online now
Here's some info on the fastener sizes if it helps at all. Not a long read.
https://www.ford-trucks.com/forums/1...-swb-help.html
Old 11-18-2014, 09:14 AM
jmf66's Avatar
jmf66
jmf66 is offline
Thanks for the replies everyone. I'll check out Lowes and HF and see what I can come up with.
I had my unmolested panels painted and ready to go, but I found another set in the junk yard that had been cut for speakers. I grabbed them and working on modifying for 6x9's and map pockets. They're in the ugly stage now...
Has to clear the window arm
26 guage zinc coated.. doesn't weld worth a crap.
Old 11-25-2014, 05:11 PM
leonharu's Avatar
leonharu
leonharu is offline
Old 11-26-2014, 11:48 AM
jmf66's Avatar
jmf66
jmf66 is offline
Thanks. I couldn't find them on his website, but that's ok... resonateur was gracious enough to send me his old ones (THANKS Eric!). I measured the factory screws and they are bigger than #10, but smaller than #12.. interesting.
If I had to get the screws locally, I'd get #10 ss oval head screws and u-nuts.. available here at Lowes. The #12 screws would work fine, but I couldn't find the matching u-nuts anywhere.
Old 11-26-2014, 01:17 PM
leonharu's Avatar
leonharu
leonharu is offline
Sorry,I should have told you.He has them,but you have to call him.He is a nice guy that will help you out.
Stangman70
02-12-2019 06:07 AM
FordTruckfan89
10-01-2015 12:30 PM
nevaplayedk9
03-12-2015 10:01 PM
st8yd
1999 to 2016 Super Duty
12-31-2014 12:54 AM
whatdyisit
16
08-01-2008 09:23 PM
Quick Reply: Door Access Panel screws..
