Then, to the best of my knowledge, the cab will not bolt on but the bed will bolt up.
The front cab mounts are different between the 61-64 and the 65-66 cabs.
Cab mounts are different floor is different steering column hole is different and they use totally different steering columns. Bed will work with out problems. AFAIK
