EBP question
Old Nov 17, 2014 | 09:16 AM
jkey.bama's Avatar
jkey.bama
EBP question
Hi Guys. I'm a diesel dummy and got a question about my EBP readings from my Scangauge II.
2004 F350 drw SCLB 4x4 4.10 gears 5Rauto stock exhaust w/cat. 130K mi.
Truck runs great, deltas range 5-7 @ 65mph flat interstate no load.
At 74 mph on cruise, EBP ranges from 27-30. Cold start @ idle 13-16. Idle after 65 mi drive home from work 14-17. Are these ranges normal, a need for concern or a need for maintenance. Thanks in advance for your replies & input from a diesel dummy that is learning as I go.
Old Nov 17, 2014 | 09:26 AM
tim.moman's Avatar
tim.moman
Those are similar to my 04 6.0. If you pull up VGT at the same time you can see it commanding vanes to keep EBP in range.
Old Nov 17, 2014 | 09:59 AM
Misky6.0's Avatar
Misky6.0
Is there a relationship between map, bst, and ebp?
I'm thinking map (atmospheric) + bst is going to give a rough equivalent to ebp? I've watched all 3 on my SG2 just don't remember if there was anything obvious going on.. I might watch them along with vgt tonight to give myself something to do while driving home..
Old Nov 17, 2014 | 02:04 PM
tim.moman's Avatar
tim.moman
That would be interesting to figure out.
Old Nov 17, 2014 | 02:26 PM
dannyboy950's Avatar
dannyboy950
EBP
Most manuals I have read and systems I have datalogged pretty much coincide.
The PCM compares a number of values and their relationship with each other to determin how it will run.
Think of it as breathing in and out.
All sensors associated with air intake, Map; Maff; IAT1 and 2 and baro deal with the intake side. EBP deals with the exhaust side or how it breaths out..
Relative comparison of these sensors deternins how much boost [additional air} that may be needed to obtain optimal combustion conditions. The primary purpose of the whole shebang. LOL
2006powerstroke90
Sep 17, 2017 08:56 PM
inc0nsequential
Jun 1, 2013 01:18 AM
Popasmurf
Dec 11, 2012 06:45 PM
BmanRRT
Feb 21, 2008 04:59 PM
zomowiec
Jan 27, 2005 09:07 PM
