1998 ford explorer
Old Nov 16, 2014 | 08:47 AM
abogema's Avatar
abogema
1998 ford explorer
i have a 1998 ford explorer it idles ok but when you put it in drive or reverse it stalls I have replaced the fuel filter, plugs, wire, installed injector cleaner and dry gas still stalls no codes were found
Old Nov 16, 2014 | 08:54 AM
JWC 3's Avatar
JWC 3
Try cleaning the Idle Air Controll valve .
Old Nov 16, 2014 | 12:23 PM
shorod's Avatar
shorod
How old is the battery? You wouldn't be the first person to have these symptoms on a late model vehicle that was caused by a weak/old battery, even though the engine seems to start fine.
Does it stall as soon as the transmission engages drive or reverse, or only as soon as you release the brake pedal and start to move?
-Rod
Old Nov 20, 2014 | 07:56 PM
impish's Avatar
impish
Torque Converter Clutch (TCC) stuck in engaged position. Look for trouble codes. Most likely culprit TCC solenoid faulty. Rarely, mechanically bound-up clutch (in converter), hope for the former.
Like stopping a manual transmission car without releasing clutch. Kills engine. impish
2kEB
Apr 15, 2011 01:26 PM
fordfan610
Nov 29, 2010 10:41 AM
Hotrod50
Jun 8, 2006 03:38 PM
1975Ford
Nov 23, 2005 08:48 AM
stodge
General Automotive Discussion
Sep 23, 2005 11:24 AM
