'2000 Ford F-650 with International diesel has NO POWER
I have a Ford F-650 with International diesel engine and automatic transmission. Approx 80,000 miles on it.
This truck has a severe problem that it has very little engine power.
For example, if I tow an empty trailer behind it (about 4,000 lbs), it has hard times accelerating and going, say, 50 MPH on a mild incline on a highway.
On the way back I was towing the same trailer with two 9,000 lbs forklifts, and it could barely climb hills at all, I would accelerate as much as possible downhill and it would lose almost all speed uphill. (very mild inclines near Chicago).
However I look at it, the engine does not produce nearly enough power.
We did change the air filter and a fuel filter on top of the engine. However, this did not help.
Any suggestions on how I can troubleshoot this issue further or perhaps I missed some other fuel filter or some such.
I would especially appreciate a procedure to find out if lack of power is caused by starving of fuel or other problems.
Thanks
Thanks
Look for soot around the uppipes at the back of the engine. Exhaust leaks will kill the power especially at the weight you were running.
The 7.3 in medium duty trucks is not a high powered engine. I think it was around 175-190 Hp at the flywheel. On a fresh reman we had problems maintaining 70 Mph on a tow truck that weighed 12k empty.
But there is a big fuel treatment unit under the driver's seat inside the frame, which I looked it but never realized that there is one more filter in there. I will try to check it today.
