brakes problem
Old Jul 17, 2003 | 01:45 PM
qsteeler's Avatar
qsteeler
brakes problem
I put new front disk brakes on my 2001 explorer sport. For some reason I cant get the pressure built up on the brake pedal. The pedal goes all the way to the floor. The brakes work but not good. How can I fix this problem. OH, I also had to replace to fluid resivoir cap that I lost with another one. maybe it doesnt seal correctly, but I dont think that would cause this problem would it?
Old Jul 17, 2003 | 02:39 PM
c96drumm's Avatar
c96drumm
brakes problem
Did you replace the calipers? If so, did you bleed them?
Old Jul 17, 2003 | 03:10 PM
qsteeler's Avatar
qsteeler
brakes problem
No, I Just replaced the pads
Old Jul 17, 2003 | 03:28 PM
jbond's Avatar
jbond
brakes problem
pump the brakes several times. do they get harder? If so, you need to bleed the brakes. You must have compressed the calipers to get them back over the discs with the new pads on. You almost have to open the bleed valve to do this. that will let air into the system, thus the need to bleed. If you're going to bleed them go ahead and buy a large can of fluid and bleed ALL the brakes until the fluid comes out clean and clear. never, never, take your foot off the brake until the bleed valve is closed completely.
Nealcrenshaw
Jan 23, 2015 05:31 PM
animaldawg
Jun 25, 2014 11:27 AM
Darky
Oct 24, 2012 05:29 PM
tlb
Mar 19, 2012 06:22 PM
rungunner
May 6, 2011 07:54 PM
