Sponsored by: Real Truck
Another Power Steering Question
Old Nov 15, 2014 | 12:54 AM
brunobrunoruch's Avatar
brunobrunoruch
4wd Low
I have a 2002 F250 SD with a 7.3 Diesel.
The problem I am experiencing is that when the truck is moving forward, in drive, at slow speed there will be a growling -whine that I think is the power steering pump or a valve in that system passing fluid. When I then step slightly on the brake the steering wheel will turn about 1/8 of a revolution. Sometimes right , sometimes left and the pedal will kind of pulse. Have flushed system, problem still here. The rest of the time brakes and steering seem fine, front brakes are new. ABS sensors have been replaced. Do Not want to just start replacing parts.
I need your help!
Power Steering Pump?
Booster?
Steering Box?
ABS System problem?
Thanks
Sous
101
Oct 30, 2020 12:07 PM
Reckless
Jan 5, 2010 11:54 AM
icovy
Dec 12, 2006 06:03 AM
klhanson74
Aug 9, 2006 09:27 AM
jcab
Oct 20, 2004 11:18 PM
