Sponsored by: Real Truck
Transmission Issue
Old Nov 13, 2014 | 09:05 PM
Archie1066's Avatar
Archie1066
Transmission Issue
I have a delay when I put my truck into gear. It only happens when I have turned the truck back on. It happens in forward as well as reverse. Does anyone know what is causing this? Syncros?
Old Nov 14, 2014 | 12:56 AM
Bently_Coop's Avatar
Bently_Coop
More information about what truck you have would be a good start. Year, Engine, Automatic or manual?
Old Nov 14, 2014 | 05:36 AM
Archie1066's Avatar
Archie1066
Its a 2005 F350 diesel.
Old Nov 14, 2014 | 06:18 AM
Archie1066's Avatar
Archie1066
6.0 deisel...it has 225,000 miles.
Old Nov 14, 2014 | 06:46 AM
ashleyroachclip's Avatar
ashleyroachclip
Auto.attic or manual transmission.
Syncros would be a manual transmission.
Old Nov 14, 2014 | 08:36 AM
Bently_Coop
2005 automatic transmissions are the 5R110. Don't here about many issues with those. Best bet is to scour the 6.0l tech folder or search the transmission on google with like issues.
When was the most recent service?
Old Nov 14, 2014 | 11:36 AM
droldsmorland's Avatar
droldsmorland
Wait for Mark K to pipe in as Im still learning these TorqueShifts...but this has been discussed before. I believe its solenoid or line pressure related unless you have hard part failure. Have you scanned the computer for any stored or active codes? Id do this first then dig deeper.
Did you do the basics like check fluid level? Whens the last time the filter and fluid got changed? Are you using the correct fluid etc? 225K is getting up there especially if its never had a fluid and filter change.
This link is pretty comperhensive:
https://www.ford-trucks.com/forums/8...+drive+reverse
Old Nov 14, 2014 | 12:02 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
He still hasn't said if it is an automatic or a manual.
If it is a manual then the delay is operator error. Most likely it is an automatic, since about 95% were.
Since automatic transmissions don't have synchros, we can eliminate that as a possibility.
The cause of most engagement delays in the TorqShift are sticky solenoids. Old, worn out fluid will cause the solenoids to stick. Sometimes changing the fluid will free them up. It will take some time with new fluid before any change becomes noticeable, if it helps at all.
Old Nov 15, 2014 | 08:11 AM
speakerfritz's Avatar
speakerfritz
my neighbor had the same problem. he had 240K miles on it with 40K being his. never changed the fluid and when I checked it , it was black. we drained the fluid and replaced the filter and it behaved much better...but still not the way its supposed to be...probally needs some soft parts work from running with old fluid for so long.
kwagner115
Mar 7, 2019 01:07 PM
totalltom
Nov 26, 2017 11:38 PM
digicon
2004 - 2008 F150
Oct 2, 2017 03:15 PM
Dgray1982
Jan 4, 2014 07:38 AM
