No start cold
Old Nov 14, 2014 | 01:08 PM
Joeys199's Avatar
Joeys199
No start cold
6.0 psd has a new icp sensor and pigtail which seem to be wired correctly because it shows the pressure when the engine is runing and as you drive around it changing but when the truck is cold it won't start unless you keep cranking or disconnect icp sensor and has a code for p0683 glow plugs. What's you opinion on what's wrong????
Old Nov 14, 2014 | 04:53 PM
05F250DSL's Avatar
05F250DSL
Your truck has told you what is wrong. You need to solve the glow plug issue. In a Diesel engine there is no spark. The heat cause by compression fires the fuel/air mixture. The glow plugs preheat and help the combustion process when cold. Without them it's a real bear to get these trucks started. I do not know if that code is general for the glow plug control or only for some of the glow plugs. From the sound they all are not working. Have you checked fuses and relays? An the wiring on the passenger side valve cover near the icp is the glow plug control
6point0
Jan 27, 2018 05:30 PM
Jordo88
Oct 23, 2016 11:05 AM
RobertJohn
Dec 23, 2013 03:20 PM
oldgameandfishdiesel
Jan 29, 2010 11:49 AM
Ed the outdoorman
Jul 9, 2003 10:17 PM
