Modular V10 (6.8l)
V10 excursion, fuel pressure drop, long crank
Old 11-13-2014, 07:26 PM
lawlfailmail's Avatar
lawlfailmail
lawlfailmail is offline
270k miles on a v10 excursion, 2005, got cold today, went to start and had to crank for 3x as long as usual, motor caught, fired immedietly, had absolutely no issues. went to work, hooked up pressure tester to fuel rail, got to 35psi and no drops or anything when running, shut off, dropped down to 30 psi within 2 seconds, down to 20 in 10 seconds, then 0 in less then 30. are we talking bad fuel pump check valve or whtaver is called, or a leaking injector? i have absolutely no codes, not misses, no loss of power. i dunno.
Old 11-14-2014, 02:43 AM
Bently_Coop's Avatar
Bently_Coop
Bently_Coop is offline
Being that you checked the pressure I would guess your on the right track. Might try changing the filter prior to dropping the tank if it hasn't been done in a while. Since your pressure dropped that would tell me it isn't a injector though.
If it is a fuel pump here is a how to from the Excursion section. A few other Excursion members have had the same issue.
https://www.ford-trucks.com/forums/1...l#post12782162
Old 11-14-2014, 06:12 AM
Im50fast's Avatar
Im50fast
Im50fast is offline
In the meantime you don't have to tax your starter and battery: just cycle the key on and off before cranking.
Turn to On, wait about 3seconds, then back off- then immediately on, wait 3 seconds, then off then directly to Crank-start.
Old 11-14-2014, 07:29 AM
lawlfailmail
exactly what i did this morning. started right up
Old 11-16-2014, 07:45 PM
krewat's Avatar
krewat
krewat is offline
Site Administrator
Fuel pressure regulator is leaking back. If you had a leaky injector, it would hydro-lock.
But then, I never really noticed if my fuel rail holds pressure after the key is off. Once you turn the key on, the fuel pump should bring up the pressure quick.
Hobie16
1999 to 2016 Super Duty
05-18-2017 06:56 AM
perryg114
Modular V10 (6.8l)
03-15-2016 09:06 PM
Jrork
Modular V10 (6.8l)
06-14-2015 11:56 AM
lawlfailmail
12-01-2014 01:48 PM
Bob_Flynn
11-27-2009 07:17 AM
Quick Reply: V10 excursion, fuel pressure drop, long crank
