driveline removal
Old Nov 13, 2014 | 01:56 PM
papabills54's Avatar
papabills54
driveline removal
what's the best way to get the driveline unstuck. I removed the bolts but she's really stuck on there. I used a rubber mallet but she wont move. I don't want to break anything so any suggestions would be appreciated.
bill
Old Nov 13, 2014 | 02:25 PM
Doc's Avatar
Doc
Take a small hammer and LIGHTLY tap on the front yoke where it slides into the transmission. Those splines are probably fused together, and that will free it up some. As you know, the driveshaft has to slide forward slightly to release at the back end. Otherwise, just get a big pry bar or screwdriver and see if you can separate the rear U-joint from the yoke on the differential. Wrap some tape around the two exposed cups on the U-Joint so they don't fly off.
Old Nov 13, 2014 | 02:45 PM
papabills54
Doc I should have mentioned it was a 9" ford rear and its stuck on the rear flange of the rear end. But I'll give it a try thank you.
Bill
Old Nov 13, 2014 | 03:12 PM
Doc's Avatar
Doc
Oh, okay. Good luck. I own a bunch of farm equipment, lots of 3-point stuff. I've had plenty of misery with frozen drive shafts, etc.
Old Nov 13, 2014 | 05:22 PM
GLR's Avatar
GLR
Please make sure the truck is securely supported or wheels blocked if on the ground.
There was a guy killed a few years ago in Martinsville, VA when he disconnected the driveshaft. The vehicle rolled of the ramps on to him.
Old Nov 14, 2014 | 04:51 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Bill
Just to be clear, you are trying to separate driveshaft from rear yoke at the u-joint, right? Once the two cap straps are removed I've never had an issue separating them.
Old Nov 14, 2014 | 07:50 AM
DR Smith's Avatar
DR Smith
It sounds like this is a custom set up , Make sure there is room at the front yoke for the shaft to slide into the tail shaft . Or is this shaft bolted to a four speed at the transmission ? If so there could be no play in the shaft length , You may have to lift the frame up to take weight off the rear to give you wiggle room .
robert_l_ross
Jun 19, 2011 10:06 PM
justshootme84
Aug 16, 2006 01:44 PM
1977_250_460_C6
Apr 7, 2005 03:22 AM
desperado_18_2000
May 22, 2001 09:41 AM
nitro94
May 6, 2000 10:56 PM
