91 Ranger Tranny
Old Nov 11, 2014 | 07:43 PM
Green Booger's Avatar
Green Booger
91 Ranger Tranny
So I've got a 91 Ford Ranger 2.9 manual 4x4 with the fm146 transmission in it. The truck has 150k miles on it.
So I started to have some problems with my tranny at around the beginning of October. When I had it in 4th gear and I was coasting down the road at about 35-45 mph it would pop out of gear. This problem began to occur more and more. The problem has gotten worse. Now I can't get it into 4th gear. I have to pull with all my might and hope that it will stay in when I take the clutch out..
All of the other gears (1st, 2nd, 3rd, 5th, and R) are having no problems what so ever. After doing some research online I saw ALOT of people complaining about this tranny and swapping it out with a different one. I was hopping that someone could explain to me what exactly is wrong with it.
I did take it into the shop and the mechanic said there was something wrong with the bearings? Just wondering if someone was having the same problems and was able to fix it in a reasonable amount of money.
Or if there is someone who has torn it apart I need them to help me put it back together.
Old Nov 11, 2014 | 08:26 PM
Backwoods351's Avatar
Backwoods351
I don't know much about that trans, but your problem sounds like either that synchro or the gear itself for fourth is gone. You could it rebuilt, not sure on the cost that would depend on the shop. If you were carefull enough you could do it yourself most Manuel transmissions aren't super complex. I'm getting ready to rebuild the one in my 92 se-r sentra. I have no 5th gear in it. Have you check the fluid level in the trans to see what looks like or if it's low?
Old Nov 11, 2014 | 11:30 PM
Mikeman's Avatar
Mikeman
Before there were synchros, there was double-clutching. You could try double-clutching it when shifting to fourth and see if that helps. Of course, that's not a fix, really.
There are a number of possible causes like sloppy shifter, bent shift forks, worn bearings, worn dogs, worn synchros and probably more. Some of these may or may not apply depending on the design. Google "manual transmission [fill in the blank] symptoms" or "manual transmission pops out of gear". You'll find lots of information out there.
Here's a link to a book that discusses various problems: How To Rebuild and Modify Your Manual Transmission - Robert Bowen - Google Books
From what I've read, the FM146 has a plastic ball on the end of the shift lever inside the tranny. It doesn't last forever and will lead to a sloppy shifter. I don't know of a source for the ball only. It seems like the solution has been to replace the entire shift lever/ball assembly.
I don't think the cause can be definitively determined without some amount of disassembly. You might be able to take a peek from the top by removing the top cover, but I'm not sure if that can be done with the tranny in place.
Old Nov 12, 2014 | 09:20 AM
Green Booger
Backwoods351,I would like to tear down the engine and rebuild it. But I'm afraid i won't be able to get it back together at the end. So I was looking for someone who has torn down one of these engines before.
Old Nov 12, 2014 | 09:22 AM
Green Booger
Mikeman, I don't think it is the plastic ball because all of the other gears work perfectly. Its just 4th. Its to the point where 4th doesn't work at all.
I have googled it but I can't find anyone actually working on my transmission.
Old Nov 12, 2014 | 09:49 PM
Mikeman's Avatar
Mikeman
This might be some help: https://www.ford-trucks.com/forums/1...m145-pics.html
Here's something else to consider: Transmission Swap (FM146 to M5OD) and Complete Clutch Upgrade
BigOldBlueTruck
13
Mar 28, 2014 07:16 PM
USCowboy
Dec 9, 2011 05:37 PM
mositso
Oct 10, 2010 03:53 PM
shanksyamaha
Modular V10 (6.8l)
Jul 18, 2009 11:30 PM
midge555
Nov 29, 2006 05:23 PM
