Subwoofer Upgrade
Old Nov 11, 2014 | 12:29 PM
CMill250's Avatar
CMill250
Subwoofer Upgrade
Hey Guys - I just got done reading pages of info on this but can't find my answer. Has anyone simply changed out the factory 8" Subwoofer speaker? I don't want to wire anything or change the box, just simply want to know if someone has tried this and the results.
Thanks for any help.
Old Nov 11, 2014 | 02:59 PM
Lastwagen's Avatar
Lastwagen
Subwoofers are designed for peak performance within a given enclosure (air volume). Just changing to a different speaker (even though high quality) might not increase the bass in the factory enclosure. It might even get worse or sound the same as what you have. I would guess a short throw voice coil would be one attribute to consider in a different speaker. Good luck.
Old Nov 11, 2014 | 06:03 PM
smoky_diesel's Avatar
smoky_diesel
what are you trying to achieve?
Old Nov 11, 2014 | 07:53 PM
Cajunboxer's Avatar
Cajunboxer
Yes I have tried in my 2012 F250. Run into a few problems. First could not find a good quality speaker (in my opinion) that had a shallow mount to fit into the factory box. Second problem trying to wire up speaker to the factory sub amp. So in the long run I replaced the entire subwoofer system in my trucks. In my 2012 I put one 10" sub with amp. Sounded pretty good, but I wanted more.( In my previous truck 2011 Megacab I had a MOJO 10" WOW). So I had a box built for to 10" subs. Sounded worse. So went back with the single 10' sub. In my 2013 F350 I installed two 8" subs and amp. Sounded great. I also have the same setup in my 2015 F250
Old Nov 12, 2014 | 09:17 AM
CMill250's Avatar
CMill250
Better and more bass without wiring a new amp, if I can get the bass up a bit I'll upgrade the rest of the door speakers if not I won't.
My thinking is I've had 150w sealed subs that sounded 10 times better than this stocker that were not high quality. So if I can fill the factory box with some Polyfill and a better sub I should get much better bass.
Well that's the thought anyway, may just need to buy one and see.
Old Nov 12, 2014 | 10:41 AM
smoky_diesel
In my opinion you will also need more power to get 'better bass' (aka louder). The system is less efficient because the sub is behind the seat. I run 500W and it's 1/4 the output of the exact same equipment when installed in a center console location.
The subwoofer output from the factory amp has a huge peak in it's response at 40hz. This was done to get best performance out of the factory sub/box system. It doesn't work well with aftermarket sub/amp setups. It is very difficult to restore this signal, a custom filter would need to be built. It's on my project list. My band aid for now is a sub level control to prevent the sub from beating itself to death.
I'm sure your search already found this thread:
https://www.ford-trucks.com/forums/1...r-upgrade.html
92F150XLT
Jan 22, 2017 07:15 PM
Crownline04
2004 - 2008 F150
Jun 8, 2008 10:16 AM
RyanMiller
Jun 29, 2005 06:46 PM
ScottyDaBody
Sep 25, 2003 03:37 PM
Fordzilla_4X4_King
Aug 30, 2003 09:14 PM
