2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
transmission service
Old Nov 11, 2014 | 09:36 AM
Pilgrim's Avatar
Pilgrim
2008 with 150,000 miles. Planning to change all fluids in diffs, transfer case and transmission. Anyone done this and have some tips? Front diff looks really tight to get cover off (no drain plug). Also, transmission looks tough because of no fill tube. Looks like some type of pump setup needed to get fluid back in.?
Any advice welcome.
Pilgrim
Old Nov 12, 2014 | 11:04 AM
Big's Avatar
Big
I don't know much about changing the differential fluids, but am curious about it. I did the fluid in my 2010 Expy LTD based on this video:
The pan bolts under (over) the exhaust pipe are tough to get to but not impossible. Otherwise pretty straight forward. That video poster also has a video about how to check the fluid level.
As for filling the tranny, I bought a cheap crappy pump setup from Advance Auto which, as just about every reviewer said it would, broke halfway through. Not so broken that it wouldn't work but enough to be a PITA. I spent $6 on it which even with it breaking was worth it because there is no way to gravity flow fluid into it.
Performance Tools Fluid Lubricant Pump W1141: Search no more for the best Grease Injectors at Advance Auto Parts
FWIW, I bought 8 QT of fluid from my local dealer (I needed Mercon LV which was not available otherwise). Between what i spilled and what I ended up getting into the tranny, 8QT worked for me.
Good luck. I look forward to others' experiences with changing diff fluid.
Old Nov 12, 2014 | 01:09 PM
Beechkid's Avatar
Beechkid
Here's what I have done on every vehicle (auto trans) that I have owned for 30 years....
I either drain the torque converter (if so equipped with a plug) or disconnect the trans cooler line at the radiator (which is what you have to do), fill the pan with fresh fluid, my wife starts the engine and when 2-3 quarts drain into a bucket, she shuts it off, I refill the pan and repeat until the fluid is clear and in case of the f150, 14 quarts of fresh fluid is in.
Old Nov 12, 2014 | 04:04 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The problem with the method is this transmission has a thermostat. It is just going to recirculate the fluid without flushing it. And there is no drain plug in the torque converter.
You need a heated flush machine to change all of the fluid. Some Ford dealers have them.
Old Nov 12, 2014 | 05:45 PM
Beechkid's Avatar
Beechkid
You are right Mark....I forgot to mention that I usually bypass the thermostat...On mine, its on the outside of the tranny so its easy.
jawsfree
2004 - 2008 F150
Jul 17, 2013 12:23 PM
terry-louie
Aerostar
Jun 14, 2012 09:22 AM
boatnfish
1997 - 2003 F150
Aug 17, 2008 08:17 PM
Banjo5150
Feb 15, 2004 02:43 AM
xdriver1
Apr 16, 2002 12:29 PM
